Old 08-24-2013, 06:20 PM   #1
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
AFR Problem (maybe Fuel Pump installation bad)
So my fuel pump went bad, it was making a wierd sound while driving and also my AFR was Mid 14 at WOT.
i replaced the pump it self, didnt touch wires at all.
after putting everything back together car started right up and AFR was arounf 11.5
after a couple hours car started stalling and AFR went up to 13-14 AFR
what could i have done wrong in the fuel pump installation?
thx
Old 08-24-2013, 06:32 PM   #2
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
@Sportsguy83
i know you had a problem with your pump
please help me here
Old 08-24-2013, 06:38 PM   #3
lexusb3
Drives: FRS
another problem dam man lol
lexusb3 is offline   Reply With Quote
Old 08-24-2013, 06:39 PM   #4
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by whitefrs View Post
@Sportsguy83
please help me here
What FP you installed? Depending on which one you installed the installation method changes.
Sorry for this posts mistakes, I'm on the phone!
Old 08-24-2013, 06:40 PM   #5
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
yea man
my car is Visconti Cursed lol
Old 08-24-2013, 06:40 PM   #6
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
i got the Full Blown 270
Old 08-24-2013, 06:43 PM   #7
Sportsguy83
Drives: Limited BRZ
You need to put 3 O rings and no white spacer on the top nipple to make it close like stock and hold pressure.
Old 08-24-2013, 06:46 PM   #8
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
i wonder why LJ has white spacer and 1 oring
do u know what size o ring is it?
Old 08-24-2013, 06:47 PM   #9
Sportsguy83
Drives: Limited BRZ
White spacer and one O ring should work too. Someone xjohnx posted the other day the O ring Napa part number. Look at his recent posts.
Old 08-24-2013, 06:48 PM   #10
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
so should i remove 1 oring then cuz i have 2 and white spacer now
Old 08-24-2013, 06:50 PM   #11
Sportsguy83
Drives: Limited BRZ
If you have white spacer and two O rings, I have to assume your FP canister does not close as stock with the white pins and needed to be close via the wraps or similar correct?
If so, I would remove one O rings and make it close like stock with the white pins.
Old 08-24-2013, 06:53 PM   #12
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
david can u pm me ur number please lol
imma take my pump out and send u pics
Old 08-24-2013, 07:09 PM   #13
Sportsguy83
Drives: Limited BRZ
Ok
Old 08-24-2013, 07:50 PM   #14
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
@King Tut how many orings are u using on ur FP?
cowboys, fire_is_coming
Why does the fuel pump not do well with ethanol? boredom.is.me Engine, Exhaust, Transmission 42 02-28-2019 07:21 PM
FS: Visconti Fuel Pump Sportsguy83 Engine, Exhaust, Bolt-Ons 0 03-31-2013 05:45 PM
Fuel pump issue. sevi21 Issues | Warranty | Recalls / TSB 13 02-01-2013 10:57 AM
Car fuel pump on... Genomaxter Engine, Exhaust, Transmission 5 11-29-2012 11:06 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 05:53 PM
