Old 12-27-2013, 08:46 PM   #1
afohlin
Drives: 2013 BRZ Limited
Fuel Filler Neck Problem
I went to fill my tank tonight and something didn't seem right. I thought there was a piece in the filler neck that gets pushed down when you put the fuel nozzle in. Its hard to explain but I attached a picture of what it looks like. I couldn't find a single picture of what the filler neck should look like without the gas cap on. How concerned should I be about this? I will be contacting the dealership in the morning.
afohlin is offline   Reply With Quote
Old 12-28-2013, 01:20 AM   #2
humfrz
Well, here's what mine looks like.
Looks about the same to me.
I wouldn't worry.
Old 01-01-2014, 12:43 AM   #3
Bad Habits
Bad Habits's Avatar
Drives: br zed
Silly question but have you filled all the way up recently? Did your gas gauge go all the way to full? Just curious.
Will look at my gas filler tomorrow, just wondering if this might be an issue with my car. I topped off from 3/4 to full last Sat night because I found cheap ass 93. Got in the car to reset the trip, mpg etc and noticed the gauge still said 3/4. Drove home 25 miles, no change. Shut the car off, pulled the batt cables and it still was at 3/4. Going to run it all the way down and see if it fixed itself.
Bad Habits is offline   Reply With Quote
Old 01-01-2014, 12:46 AM   #4
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Reflash or stock? I had a similar problem with a EcuTek tune, ran the car for a day and went to top it off - gauge reset like it should. Also - do you continue to fuel after the auto shut off at the pump happens? I've read that can screw with things too..... HTH.
mikalem is offline   Reply With Quote
Old 01-01-2014, 12:51 AM   #5
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
It will fix itself next time you fill it. For whatever reason these cars do that.
cjsporl1996 is offline   Reply With Quote
Old 01-01-2014, 12:58 AM   #6
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Seems to be an ECU problem if you fill up before 1/4 down or so. It's been covered here before somewhere.
Run it down below 1/2 and it should reset eventually. Topping up tends to give it fits.
Old 01-01-2014, 11:29 AM   #7
BRZnut
Drives: BRZ DGM Limited
Ya..mine did it once too when I filled up at 3/4 tank. Gauge did not come up but it corrected itself. Seems to be "normal" for these cars. These quirks are what make the twins so special!
Old 01-01-2014, 01:13 PM   #8
Bad Habits
Bad Habits's Avatar
Drives: br zed
Car is stock. I just put the gas filler in and the pump auto shut off, kicked it up another 60 cents to an even amount and done. Nothing different from any other time and my mpg wasn't affected so I figured it was nothing major.
Thanks for the replys. I hadn't even searched it as I figured it was a fluke and was just going to run it down over the week and weekend if the weather was nice and disco the battery if needed.
Grimmspeed Oil Filler Cap SilentMike Engine, Exhaust, Bolt-Ons 3 10-07-2013 10:37 AM
Fuel Gauge problem adan CANADA 2 09-24-2013 11:12 PM
AFR Problem (maybe Fuel Pump installation bad) whitefrs Engine, Exhaust, Transmission 37 08-30-2013 02:36 PM
For Sale: TRD Oil Filler cap Panman Australia Classifieds 4 04-13-2013 07:22 PM
Fuel Filler is on the Right!! Guaruja Scion FR-S / Toyota 86 GT86 General Forum 43 04-01-2012 05:55 PM
