CANADA Canada
Old 09-24-2013, 10:22 PM   #1
adan
Drives: Asphalt Scion FR-S 2013
Fuel Gauge problem
Hey guys,
I've encountered a problem and would like to know if it's something I should worry about.
I just filled up my tank and instead of my fuel gauge showing that the tank is full, the needle only goes about 7/8th of the way. After noticing this, I went to another gas station to try to fill the tank up even more. I got to put in about 1 dollar and the trigger on the pump automatically stopped. I checked my gauge again, but it still shows a tank that's only 7/8th full. Has anyone had this problem before?
Thanks in advance
adan is offline   Reply With Quote
Old 09-24-2013, 10:46 PM   #2
roddy
roddy's Avatar
Drives: '13 Ultramarine
This happens to mine once in a while if I top up the tank from 1/2 or more. If you let the tank go down to 1/4 or so before your next fill-up, I'd bet it reads fine. I did just what you did the first time this happened to me, and I wondered why it wouldn't take any more gas. Nothing to worry about.
Old 09-24-2013, 11:12 PM   #3
adan
Cool. I was wondering if it had something to do with that. I normally never fill up until my tank is low but lately, gas has been on the cheap side so I've been filling up as frequently as possible. Thanks again, roddy
Fuel Gauge is Inaccurate Surakusa Issues | Warranty | Recalls / TSB 13 09-02-2017 10:26 PM
Fuel gauge not reading properly FR-S Hot Lava Issues | Warranty | Recalls / TSB 27 10-29-2014 10:33 AM
AFR Problem (maybe Fuel Pump installation bad) whitefrs Engine, Exhaust, Transmission 37 08-30-2013 02:36 PM
Fuel gauge stuck? Nate219BRZ Issues | Warranty | Recalls / TSB 6 08-27-2012 04:40 PM
European fuel/coolant gauge face arbnpx Cosmetic Modification (Interior/Exterior/Lighting) 0 05-31-2012 12:23 AM
