Old 03-01-2014, 11:27 PM   #1
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Really weird problem: Have to fill with fuel very slowly
Past few weeks, the fill ups I have done have been very difficult. Every gas station I visit (I've tried multiple different stations, brands, etc), clicks off, as if the tank is full, as soon as I start pumping anywhere near full speed.
I originally attributed this to a few particular stations but then I returned to the station where I've been filling the car primarily for the past year and it does it too!
If I pull the handle more than 40-50%, it clicks off as if I'm full. At one station, it caused an overfill when my tank was near bone dry, filled fuel all over the car! I'm getting around 2 gallons per minute, if I'm good enough to never pull too far.
You can hear the fuel level getting high in the filler tube as if you're getting close to full, too. It's like my filler tube has shrunk. This has only been occurring over the past month. Car is nearly 2 years old, 29k on it.
Has anyone else experienced this? Going to take it to the dealer for this soon, just not sure when.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
The Following User Says Thank You to Kido1986 For This Useful Post:
dannyboy8793 (03-02-2014)
Old 03-01-2014, 11:41 PM   #2
Gaiseric
Gaiseric's Avatar
Drives: 2012 Scion TC
It goes away and that's all I know, happened to me I thought it had something to do with air and pressure but Idk
Gaiseric is offline   Reply With Quote
Old 03-02-2014, 12:16 AM   #3
kodyo
Drives: Scion FR-S
Found this article that might help:
http://m.theglobeandmail.com/globe-d...service=mobile
kodyo is offline   Reply With Quote
The Following User Says Thank You to kodyo For This Useful Post:
humfrz (03-02-2014)
Old 03-02-2014, 12:48 AM   #4
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Check for kinked line
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 03-03-2014, 03:44 AM   #5
HapaHaole
Drives: Grocery cart
Sounds like a possible EVAP system issue.
SOLD: 2014 BRZ Limited WRB 6 Speed.
HapaHaole is offline   Reply With Quote
The Following User Says Thank You to HapaHaole For This Useful Post:
neutron256 (03-11-2014)
Old 03-10-2014, 11:53 PM   #6
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
I also had this issue when my car was only a few weeks old. Turns out the tank has to be half empty before I can fill up, otherwise I would have the problem you described. I've asked a lot of people and this seems to be the thing with Japanese cars. With my previous Golf GTI I can fill up whenever I want regardless of how much petro I have left in the tank.
krayzie is offline   Reply With Quote
Old 03-11-2014, 08:53 AM   #7
Kido1986
Dodging cones
Kido1986's Avatar
That's not the issue here; it happened when I was running on fumes as well
Old 03-11-2014, 12:00 PM   #8
White64Goat
Have you tried turning the gas nozzle a different direction? I've had a couple of cars that you had to hold the nozzle at like a 4 or 8 o'clock position in stead of the usual 6 o'clock position.
The Following User Says Thank You to White64Goat For This Useful Post:
ZZT86 (06-18-2014)
Old 03-11-2014, 12:18 PM   #9
krayzie
Drive From Home
krayzie's Avatar
The dealer told me there's a vent for the gas tank that can get clogged up with spiderwebs or other foreign objects that can cause this problem, and once they clear this vent (which is a neck that runs parallel to the fuel filler), this problem should go away. They said they have seen this even with new cars sitting on the lot.
The Following User Says Thank You to krayzie For This Useful Post:
andrew20195 (03-11-2014)
Old 03-11-2014, 12:19 PM   #10
mid_life_crisis
Drives: FR-S 10 #103 AT
Never experienced it with this car but my teenager's old PT Cruiser did it. It was brutal. You could barely get it to take gas at all. Turned out there is a filter in the evap system that gets screwed up if you "top off" the gas when you fill up, which his biological father taught him to do. Odd thing is that replacing the filter only worked for a while and it came back even though the kid swears he stopped topping the car off.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
The Following User Says Thank You to mid_life_crisis For This Useful Post:
Old 03-11-2014, 12:24 PM   #11
andrew20195
Drives: 2013 Subaru BRZ
Both of these situations could cause this problem. It basically comes down to either the vapor recovery valve is sticking or the air passage is clogged somehow.
andrew20195 is offline   Reply With Quote
Old 03-11-2014, 01:04 PM   #12
Kido1986
Dodging cones
Kido1986's Avatar
It sounds blocked. You can hear it getting 'full' right away when you start pumping, like thereis air filling too much space.
Going to the dealer tomorrow to service
Old 03-11-2014, 06:36 PM   #13
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
This sounds like the evaporative emissions filter is clogged. When filling do you stop when it clicks off or do you pull the handle a few more times to top it off? Topping off like that can cause fuel to flood the filter and clog it.
The Following User Says Thank You to neutron256 For This Useful Post:
andrew20195 (06-18-2014)
Old 06-17-2014, 05:17 PM   #14
CaptDale
Drives: '14 BRZ
Some people have had issues with the inside of the fuel filler hose collapsing. The inner liner falls off of the outer so you can't see it till you take off the tube and look inside. Dealer should replace under warranty.
CaptDale is offline   Reply With Quote
The Following User Says Thank You to CaptDale For This Useful Post:
fatalelement (12-21-2014)
Slowly losing (and smelling) coolant PantsDants Issues | Warranty | Recalls / TSB 11 01-31-2016 10:52 PM
Here we go -- Slowly, but surely MadFRS Member's Car Journals 16 02-24-2014 07:30 PM
Fuel Filler Neck Problem afohlin Issues | Warranty | Recalls / TSB 7 01-01-2014 02:13 PM
Fuel Gauge problem adan CANADA 2 09-25-2013 12:12 AM
AFR Problem (maybe Fuel Pump installation bad) whitefrs Engine, Exhaust, Transmission 37 08-30-2013 03:36 PM
