Drives: 2013 FRS, 1993 Toyota FZJ-80
Jackassery, hit curb in FRS bent control arm
So, I have this friend.
I have only driven 4X4's and trucks, this FR-S is my first car. Was drifting and getting some confidence. All that was shattered when I smacked the snot out of the curb with the front drivers side wheel and tire and bent the lower control arm good. Yes, yes, I'm a newb and this will be an expensive learning lesson. Replaced the control arm and everything looked straight, other than the need for an alignment. During the test drive when turning the steering wheel driver, from straight you could feel some resistance. The steering wheel would also look like its having a seizure if you stopped while the tires were straight. I pulled everthing off and looked for anything bent in with the steering but didn't see anything noticeable with the naked eye. What would be bent? is it that bar going from the tie-rod to the power steering? Or is my whole rack-pinon toast? Yes, I'm an idiot. I'm learning. Shit happens. Flame away. Cheers, Angelo |
Drives: old
You probably tweaked the Steering Rack. Is there excess resistance steering only to left?
Drives: Scion FR-S
Did you try to fix it yourself? Did the exact same thing but to the rear, so don't feel too bad. Except I took it to the dealership and paid the deductible. Ended up being about $4500 in the end, but it got fixed like new.
Drives: old
#6 | |
![]() In addition to the LCA being bent, as mentioned, the steering rack could be whacked out. Also, the strut may be damaged. The wheel may be bent. The wheel bearings may be damaged. I suggest you take it to a good front end shop and have it fixed proper.... ![]() humfrz |
#7 | |||
Inspected the strut and it looked undamaged, wheel bearings felt fine. I have already replaced the wheel and tire. It's going to the stealership tomorrow. Thanks, Angelo |
Site Moderator
Drives: Stuff
So did you or did you not get an alignment?
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
Here's a picture of the new control arm next to the bent one and a picture of my FRS.
#10 |
Drives: 2013 Raven FRS MT
Shit happens. Sometimes it's expensive at times. At least you're okay and the car can be repaired. Keep us posted on your car's return to full health. Cheers.
#11 |
#12 |
Site Moderator
Drives: Stuff
In that case get it aligned first. Alignment can make it feel really bad if it's bad enough.
-Dave
#13 |
Drives: SWP BRZ
sorry to hear that. everyone does once in a while and bad luck happens.
yeah like others said get alignment first. get manual spec of alignment for FRS/BRZ and shop may be able to get alignment manually |
#14 |
| Bent lower control arm | Notso | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 01-13-2014 08:52 PM |
| Bent Rod Pics.. | FullBlown | Forced Induction | 47 | 10-27-2013 08:02 PM |
| New Wheels Bent | Admired | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 39 | 10-20-2013 09:39 PM |
| Bent Rim | Sir Alex | Mid-Atlantic | 5 | 08-09-2013 03:34 PM |
| hit a curb HARD, traction control and ABS light on now need help plz! | EvoXDD | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 26 | 02-28-2013 04:08 PM |
