Old 10-23-2013, 01:40 PM   #1
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Bent Rod Pics..
So it seems like most of the time when failures happen, there is so much damage that it is hard to tell which part let go first.
Well, one of our friends from from Puerto Rico went to the track ,and this was the result of a 470hp and a bad tank of gas.
Our shortblock is going into this car now to ensure this won't happen again. He was very lucky to not have put a hole through it.
FullBlown is offline   Reply With Quote
The Following 7 Users Say Thank You to FullBlown For This Useful Post:
brzaapi (10-23-2013), charged86 (10-26-2013), cobrabyte (10-23-2013), CSG Mike (10-23-2013), F1point4 (10-23-2013), RedAlert (10-24-2013), Sportsguy83 (10-23-2013)
Old 10-23-2013, 01:46 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I have a mutual friend with Georgie and was told this story two days ago. Nice to see the pics.
@FullBlown I applaud the fact you guys are honest and transparent and put this kind of stuff out there. It benefits everyone and we all learn everyday what are the limits of this motor. I know for a fact Puerto Rico's gas is pure awful piss.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
FullBlown (10-25-2013)
Old 10-23-2013, 02:54 PM   #3
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Can you explain this for the noobs. How did bad gas cause the rods to bend.
post_break is offline   Reply With Quote
The Following User Says Thank You to post_break For This Useful Post:
MightyMeeple (10-23-2013)
Old 10-23-2013, 03:08 PM   #4
SkullWorks
Drives: SSM LT MT BRZ
"Bad gas" generally doesn't have the octane to support the desired fuel and timing conditions, this will lead to peak cylinder pressure happening when the crankshaft is not yet past top dead center so the piston is still coming up in the bore. whatever is weakest bends or breaks, because you are pushing with great force on both sides of the piston.
The above description is what you would call pre-ignition or detonation or knock, depending on what exact circumstances lead to the "bad combustion event".
I hope that is some what non-confusing.
SkullWorks is offline   Reply With Quote
The Following 13 Users Say Thank You to SkullWorks For This Useful Post:
20valvewynn83 (10-25-2013), armythug (10-26-2013), asher187 (10-26-2013), clintavo (10-26-2013), DriftEightSix (10-24-2013), F1point4 (10-23-2013), fasteddy (10-24-2013), Gums (10-24-2013), mfbmike (10-23-2013), Pekingduck (10-24-2013), Pete156 (10-23-2013), RedAlert (10-24-2013), Sportsguy83 (10-23-2013)
Old 10-23-2013, 03:08 PM   #5
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Bad gas ( maybe water in it ?) caused a hydrolock ?
Old 10-23-2013, 03:10 PM   #6
SmsAlSuwaidi
Boosted
Doesn't detonation usually affect top of the stroke and less strain/force on the sides ?
@FullBlown ?
Old 10-23-2013, 03:10 PM   #7
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Detonation/ preignition from low quality fuel or too much ignition advance will cause rods to bend/break. Not only that, but it can beat up the bearings and ruin other things as well.
The Following 3 Users Say Thank You to FullBlown For This Useful Post:
20valvewynn83 (10-25-2013), F1point4 (10-23-2013), Sportsguy83 (10-23-2013)
Old 10-23-2013, 03:22 PM   #8
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
knock and ping are not the same as pre-ignition. What you're describing above is pre-ignition when the combustion takes place, in full, way too early pushing against the piston while it's still traveling upwards.
Ping or Knock is the result of an uncontrolled burn. Where the heat and compression begins to ignite part of the air/fuel mixture (usually around the edges of the piston) and the spark ignites the other part. It's essentially the meeting of 2 separate flame fronts that cause the full ignition to occur outside of the optimal timing. This meeting of flame front causes a massive spike in heat and cylinder pressure which creates a shockwave at a high frequency that we hear as a ping or knock. Like metal balls in a coffee can.
Pinging/Knocking is generally not the cause of rods bending (that would be pre-det), it's the cause of pistons melting, valves burning, ring lands cracking or engines overheating. What's funny is the user manual in my Econoline Van says that occasional pinging is "normal and to be expected" which I found odd. I guess that's the difference between a cast iron engine and aluminum one.
Pinging/knocking:
Note: Pinging is not an explosion it is merely a very fast combustion, which exceeds the healthy limits. The propagation of an explosion's pressure wave would be far higher,
something like 2000m/s. (m/s = metres per second)
edit: forgot to add this:
PRO86 | WTCC | STL
The Following 4 Users Say Thank You to rice_classic For This Useful Post:
20valvewynn83 (10-25-2013), Astroboy (10-09-2017), DriftEightSix (10-24-2013), Gums (10-24-2013)
Old 10-23-2013, 03:34 PM   #9
slowmo
slowmo's Avatar
Drives: '13 BRZ
are those stock rods ?
400+whp
slowmo is offline   Reply With Quote
Old 10-23-2013, 03:36 PM   #10
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Yes they are
Old 10-23-2013, 03:49 PM   #11
SkullWorks
Pinging/knocking:
I didn't go into full detail because a noob answer was required. It is easy to lay out the differences in text but the reality of the situation is all of these events are very closely tied and often happen concurrently with one another, Knock is an audible noise, it doesn't designate, when described in text, what occurred internal to the combustion chamber. Pinging is much the same, a description of the audible results of bad combustion. Pre-ignition describes a combustion event that occurs before desired, (generally ~14 degreees ATDC is when you want peak cylinder pressure)
Detonation describes the event that generally immediately follows...because now you have fuel burning and pressure building from 2 sources...1 mechanical 2 thermal...
detonation alone is just a slower death,
it's akin to the all squares are rectangles but not all rectangles are squares statement.....if you can hear it, it's knock (or pinging) which means it is a rectangle, but not necessarily a square, if it bends a rod it is most assuredly a square...which also happens to be a rectangle...
The Following 2 Users Say Thank You to SkullWorks For This Useful Post:
andrew20195 (10-25-2013), Ozzman (10-30-2013)
Old 10-23-2013, 03:56 PM   #12
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 10-23-2013, 03:56 PM   #13
MightyMeeple
Slower than Fast
MightyMeeple's Avatar
Drives: BRZ Limited 6MT
MightyMeeple is offline   Reply With Quote
Old 10-23-2013, 08:49 PM   #14
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
Oh my....
Do they get E85 in PR?
Circuit Motorsports is offline   Reply With Quote
Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 856 06-14-2018 03:53 PM
New Wheels Bent Admired Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 39 10-20-2013 10:39 PM
VIP Modular VRC13 Wheels Bent Admired Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 10-20-2013 01:16 PM
Bent Rim Sir Alex Mid-Atlantic 5 08-09-2013 04:34 PM
More stock pics. My Raven FR-S with graffitti background. Sick Pics Hardrock4445 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 11-12-2012 12:29 AM
