Old 12-24-2013, 03:44 PM   #1
Notso
Drives: Subaru BRZ
Bent lower control arm
So I pulled into my driveway the other night, it had snowed, and I slid into a curb at about 4mph no joke. I thought nothing of it, forgot about it until the next morning when my steering wheel was off and noticed the steering was loose. Also my traction control light is constantly on along with the abs light. I ordered parts last night. I was wondering the difficulty of replacing this part. I've worked with roders/pads/shocks before so i'm experienced in the wheel area. Also replacing this will hopefully fix the abs/tc?? i'm hoping?? anybody experienced in this area? any thoughts/advice would be awesome, thanks
Notso is offline   Reply With Quote
Old 12-24-2013, 04:53 PM   #2
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
The steering wheel being not centered would be the reason for the dash lights. Get a new arm and make sure it's aligned correctly after. If the lights are still on after it's probably a damaged sensor.
Rayme is offline   Reply With Quote
Old 01-13-2014, 04:08 PM   #3
John92
Drives: White scion frs
I did the same thing in my car the LCA was bent and the slide caused my power steering rack gears to be jammed, toyota had to reset the lights once everything was installed .
John92 is offline   Reply With Quote
Old 01-13-2014, 08:26 PM   #4
wparsons
wparsons's Avatar
If the steering feels loose, it's probably a tie-rod more than a bent LCA. I would have a look at all the parts before just buying a random part and hoping that's the issue.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
diss7 (01-13-2014)
Old 01-13-2014, 08:52 PM   #5
pche
Guy on internet
Drives: Slowly
Roders....lol
Sorry but that crack me up. You should jack up the front end, unload the weight and grab the tire at 3 and 9 position and wiggle. Might be easier if you have a friend do that while you look for the moving part. Sounds like a tie rod to me. There're inner and outter tie rods, make sure you get the right part.
pche is offline   Reply With Quote
SPC Lower Control Arms(Old and New) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 79 07-10-2017 09:58 PM
Front lower control arm balla_08 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 11-14-2013 08:47 PM
WTB: Front Lower Control Arm and Rear Upper Control Arm YDNA Brakes, Suspension, Chassis 0 11-10-2013 04:40 AM
FRONT lower control arms. J-W Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 10-31-2013 09:24 AM
SPC Adjustable Lower Control Arm on SALE!!! Powerhouse Racing Brakes, Suspension, Chassis 1 10-07-2013 10:21 AM
