Old 02-16-2014, 04:57 PM   #1
Doughboy
Drives: 2013 FRS, 1993 Toyota FZJ-80
Jackassery, hit curb in FRS bent control arm
So, I have this friend.
I have only driven 4X4's and trucks, this FR-S is my first car. Was drifting and getting some confidence. All that was shattered when I smacked the snot out of the curb with the front drivers side wheel and tire and bent the lower control arm good. Yes, yes, I'm a newb and this will be an expensive learning lesson.
Replaced the control arm and everything looked straight, other than the need for an alignment. During the test drive when turning the steering wheel driver, from straight you could feel some resistance. The steering wheel would also look like its having a seizure if you stopped while the tires were straight. I pulled everthing off and looked for anything bent in with the steering but didn't see anything noticeable with the naked eye.
What would be bent? is it that bar going from the tie-rod to the power steering? Or is my whole rack-pinon toast?
Yes, I'm an idiot. I'm learning. Shit happens. Flame away.
Cheers, Angelo
Doughboy is offline   Reply With Quote
Old 02-16-2014, 06:06 PM   #2
Ozzman
Drives: old
You probably tweaked the Steering Rack. Is there excess resistance steering only to left?
Ozzman is offline   Reply With Quote
Old 02-16-2014, 07:06 PM   #3
Doughboy
Yes, only when going left. The steering wheel was also fully right when I hit the curb.
Angelo
Old 02-16-2014, 07:37 PM   #4
kodyo
Drives: Scion FR-S
Did you try to fix it yourself? Did the exact same thing but to the rear, so don't feel too bad. Except I took it to the dealership and paid the deductible. Ended up being about $4500 in the end, but it got fixed like new.
kodyo is offline   Reply With Quote
Old 02-16-2014, 08:30 PM   #5
Ozzman
Drives: old
Angelo
Your rack is jacked Jack. Replace it and hope none of the electronics are damaged.
Old 02-16-2014, 09:16 PM   #6
Well, Doughboy ..... that may be an expensive lesson for you .....
In addition to the LCA being bent, as mentioned, the steering rack could be whacked out. Also, the strut may be damaged. The wheel may be bent. The wheel bearings may be damaged.
I suggest you take it to a good front end shop and have it fixed proper....
Old 02-16-2014, 09:59 PM   #7
Doughboy
I replaced the LCA myself. Took it for a test drive afterwards and the steering felt horrid. It's going to the dealership tomorrow.
That's what it's looking like. Thanks Ozzman.
Expensive lesson for sure.
Inspected the strut and it looked undamaged, wheel bearings felt fine. I have already replaced the wheel and tire.
It's going to the stealership tomorrow.
Thanks,
Angelo
Old 02-16-2014, 10:13 PM   #8
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
So did you or did you not get an alignment?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-16-2014, 10:17 PM   #9
Doughboy
Here's a picture of the new control arm next to the bent one and a picture of my FRS.
Old 02-16-2014, 10:24 PM   #10
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Shit happens. Sometimes it's expensive at times. At least you're okay and the car can be repaired. Keep us posted on your car's return to full health. Cheers.
AVodka14 is offline   Reply With Quote
Old 02-16-2014, 10:28 PM   #11
Doughboy
I went to the alignment shop, but they couldn't do it because they didn't have the FR-S or BRZ in their database. So, no I didn't get it aligned.
Old 02-16-2014, 10:40 PM   #12
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
In that case get it aligned first. Alignment can make it feel really bad if it's bad enough.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-16-2014, 11:04 PM   #13
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
sorry to hear that. everyone does once in a while and bad luck happens.
yeah like others said get alignment first. get manual spec of alignment for FRS/BRZ and shop may be able to get alignment manually
Old 02-16-2014, 11:04 PM   #14
Nice wheels......
Bent lower control arm Notso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-13-2014 08:52 PM
Bent Rod Pics.. FullBlown Forced Induction 47 10-27-2013 08:02 PM
New Wheels Bent Admired Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 39 10-20-2013 09:39 PM
Bent Rim Sir Alex Mid-Atlantic 5 08-09-2013 03:34 PM
hit a curb HARD, traction control and ABS light on now need help plz! EvoXDD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 02-28-2013 04:08 PM
