Old 02-09-2014, 10:45 AM   #1
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Aligning Tips: Assistance
Hi everyone, I searched for this but didnt really find what I needed.
I installed a catback and front-pipe yesterday. I spent quite some time trying to position the tips perfectly in the center of my diffuser, and without one tip poking out more than the other. I cannot get this right for some reason.
I loosened up the bolts, re-aligned, moved the rubber brackets as much as I could and lined everything up. Then tightened the exhaust from the front to back, re-aligning as I go. Once everything is tightened, the end result is always uneven.
Will investing in aftermarket brackets help? Perhaps I have something warped with my exhaust?
Any thoughts or tips/tricks/advice is greatly appreciated. Thanks!
SpectreRT is offline   Reply With Quote
Old 02-09-2014, 11:00 AM   #2
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
Is the catback or front pipe designed to use the OEM donut gasket or flange gasket. The difference in thickness lost if you're supposed to keep the OEM donut and go to a flange gasket will offset the exhaust.
garfull is offline   Reply With Quote
Old 02-09-2014, 11:16 AM   #3
Basket Case
Drives: 2013 Raven fr-s
what exhaust components have you installed?
Basket Case is offline   Reply With Quote
Old 02-09-2014, 11:58 AM   #4
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Thanks for replies. New exhaust mounts to OEM hangers. I've installed front pipe and catback, thats it. OEM header and overpipe.
Old 02-09-2014, 04:37 PM   #5
humfrz
Originally Posted by SpectreRT View Post
Hi everyone,
Well, what we used to do, back in the day, was to loop a length of wire around the piece of exhaust and around something substantial under the car.
Then loosen up the connections; "twist" the wire loop by inserting a screwdriver and tighten till the exhaust part was "straight", then tighten up the connections. If it didn't stay straight, loosen the connections, twist (tighten) the wire some more and re-tighten the connections.
Hey, lemmie alone ..... I said it was "back in the day" ....
Sorta like this:
Old 02-09-2014, 04:38 PM   #6
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
At this point, anything is worth a try! lol.
Old 02-10-2014, 09:37 PM   #7
steve99
I got mine to sit in the centre of the diffuser by installing some extra rubber grommets on the metal hanger straps (on the body side which is cooler) to pack out the standard flexible exhaust mounts so it all sat correctly. Needed to do this even after loosening and re-aligning
Uneven steering assistance? koevasi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 01-14-2014 09:06 AM
Diablo 3 assistance SubaSteve Off-Topic Lounge [WARNING: NO POLITICS] 10 11-19-2013 07:01 PM
Assistance on DIY front pipe install. Osiris DIY (Do-It-Yourself) Guides 3 04-18-2013 10:31 PM
FBM install assistance Gen Forced Induction 23 04-10-2013 10:46 AM
switchback LED assistance Gen Cosmetic Modification (Interior/Exterior/Lighting) 2 10-09-2012 10:41 PM
