Old 04-06-2013, 07:10 PM   #1
Gen
Drives: Scion FR-S
FBM install assistance
Hey guys, can someone advise on where to weld the bung on the oil pan? We're at a bit of a standstill and I'm having a tough time getting ahold of FBM. The instructions there litterally say
NOTE: Finish oil pan instructions and add pictures
So I'm guessing I got an old flash drive or something.
Thanks!
Gen is offline   Reply With Quote
Old 04-06-2013, 07:15 PM   #2
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
The oil return should be as close to the top of the pan as possible, and at a downward angle so as not to cause any resistance on return. It should not come close to any pulleys. It can only really go in a certain place to work properly, but that place is pretty obvious when you get under the car.
Pure Automotive is offline   Reply With Quote
Old 04-06-2013, 07:24 PM   #3
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Install your oil return line on turbo, mount fitting to said line and see where it goes. Mark it and install it there
Silverdub is offline   Reply With Quote
Old 04-06-2013, 07:28 PM   #4
crook
crook's Avatar
Drives: storm black GT
Plus I know it's obvious but just keep it in mind you'd want to make sure that where its gonna sit you can still access the bolts to the pan, don't wanna do things twice and it's easy to over look silly things like that if rushing or getting stressed/frustrated
crook is offline   Reply With Quote
Old 04-06-2013, 08:41 PM   #5
Supermassive
Supermassive's Avatar
I was so glad P&L sent me a new oil pan with the bung already welded on...I mangled the shit out of the stock one taking it off...that gasket goop subaru used is insane.
Supermassive is offline   Reply With Quote
Old 04-06-2013, 09:11 PM   #6
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Gen, it is the top right front corner. You want to mock everything up to insure you have it correct. Let us know if you still cannot figure it out
FullBlown is offline   Reply With Quote
Old 04-06-2013, 09:30 PM   #7
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Same here i bought a new one for my setup and when i took out the old one it came out looking like a pretzl
Old 04-06-2013, 09:33 PM   #8
FullBlown
FullBlown's Avatar
Drives: Scion FRS
We offer a welded pan for those who wish not to weld their own.
Old 04-06-2013, 09:44 PM   #9
crook
crook's Avatar
I have no problems welding my own, but does the premium kit come with a new pan with the bung already welded on?
Btw I have had my kit sitting at my house for the past week and a half but have been away since before it arrived and I've still got another week before I'm home so havnt been able to check if it does or not
Old 04-06-2013, 09:48 PM   #10
FullBlown
FullBlown's Avatar
Drives: Scion FRS
yes all the premium kits comes with the welded pan
Old 04-06-2013, 09:48 PM   #11
Gen
Drives: Scion FR-S
Thanks for the help guys. We just wanted to make sure.
Old 04-06-2013, 10:01 PM   #12
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
I suggest if you weld it urself to fill it with water before you install it on the engine. There could be a tiny tiny pinhole that will make a mess with time. The water will leak out right away if ghe is any hole
Old 04-06-2013, 10:22 PM   #13
Gen
Drives: Scion FR-S
Yeah we made absolutely sure
Old 04-06-2013, 10:38 PM   #14
pmccut
Drives: Blue Subarus
I ordered the base kit on 3/19 and now I'm getting nervous about the install. Have the instructions been completed for new USB sticks? I'm planning on having a shop (Works Motorsports in Sonoma, CA) do the install but still want clear instructions
pmccut is offline   Reply With Quote
Where to install amp in FRS? mit_peid Electronics | Audio | NAV | Infotainment 10 03-24-2013 01:01 PM
KW V3 on my car install ft86me DIY (Do-It-Yourself) Guides 0 03-12-2013 09:36 PM
Need help with HID install ortizwyld Cosmetic Modification (Interior/Exterior/Lighting) 4 02-21-2013 11:12 PM
Scion Roadside Assistance Telephone Number russv Scion FR-S / Toyota 86 GT86 General Forum 6 02-21-2013 10:08 PM
switchback LED assistance Gen Cosmetic Modification (Interior/Exterior/Lighting) 2 10-09-2012 10:41 PM
