Drives: Subaru BRZ
Aligning Tips: Assistance
Hi everyone, I searched for this but didnt really find what I needed.
I installed a catback and front-pipe yesterday. I spent quite some time trying to position the tips perfectly in the center of my diffuser, and without one tip poking out more than the other. I cannot get this right for some reason. I loosened up the bolts, re-aligned, moved the rubber brackets as much as I could and lined everything up. Then tightened the exhaust from the front to back, re-aligning as I go. Once everything is tightened, the end result is always uneven. Will investing in aftermarket brackets help? Perhaps I have something warped with my exhaust? Any thoughts or tips/tricks/advice is greatly appreciated. Thanks! |
#2 |
Drives: FRS(sold), AP2, R35, FJC, ED9
Is the catback or front pipe designed to use the OEM donut gasket or flange gasket. The difference in thickness lost if you're supposed to keep the OEM donut and go to a flange gasket will offset the exhaust.
#3 |
Drives: 2013 Raven fr-s
what exhaust components have you installed?
#4 |
Drives: Subaru BRZ
Thanks for replies. New exhaust mounts to OEM hangers. I've installed front pipe and catback, thats it. OEM header and overpipe.
#5 | |
Then loosen up the connections; "twist" the wire loop by inserting a screwdriver and tighten till the exhaust part was "straight", then tighten up the connections. If it didn't stay straight, loosen the connections, twist (tighten) the wire some more and re-tighten the connections. Hey, lemmie alone ..... I said it was "back in the day" .... ![]() Sorta like this: |
#6 |
Drives: Subaru BRZ
At this point, anything is worth a try! lol.
#7 | |
Drives: FT86
I got mine to sit in the centre of the diffuser by installing some extra rubber grommets on the metal hanger straps (on the body side which is cooler) to pack out the standard flexible exhaust mounts so it all sat correctly. Needed to do this even after loosening and re-aligning |
| Uneven steering assistance? | koevasi | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 01-14-2014 09:06 AM |
| Diablo 3 assistance | SubaSteve | Off-Topic Lounge [WARNING: NO POLITICS] | 10 | 11-19-2013 07:01 PM |
| Assistance on DIY front pipe install. | Osiris | DIY (Do-It-Yourself) Guides | 3 | 04-18-2013 10:31 PM |
| FBM install assistance | Gen | Forced Induction | 23 | 04-10-2013 10:46 AM |
| switchback LED assistance | Gen | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 10-09-2012 10:41 PM |
