Old 01-25-2014, 03:13 PM   #1
DeLaRage
Drives: 2013 Raven FRS
Quick question about my driver's side window..
First off, when i do the auto down it works fine. but the auto up it goes all the way up then back down to half way. Not sure what i could do to fix this. Already did the hold down for 5 seconds thing that the manual says.
Secondly, when opening the driver's side the window doesn't come down the tiny bit that it should but the passenger side is working. Any help/opinions on this would be greatly appreciated and thanks in advance !
DeLaRage is offline   Reply With Quote
Old 01-25-2014, 03:30 PM   #2
humfrz
hmmm......did you do the "hold down on the button thing" when the window was up AND down?
If so, and that didn't do it, you may consider disconnecting the battery and setting the window again.
Old 01-25-2014, 03:33 PM   #3
DeLaRage
i didn't even think about doing it up. i only did it while down. Brb time to go check. Lol
Old 01-25-2014, 03:40 PM   #4
DeLaRage
ok. It did not work, if i held the window too long past when it just closed it would go back down to half way. As to disconnecting the battery should i just remove the negative or both ? sorry for the "nooby" question.
Old 01-25-2014, 03:52 PM   #5
humfrz
On the battery, just remove one side for a few seconds.
I hope it works for you.
Old 01-25-2014, 04:02 PM   #6
humfrz
.....and.....if that didn't work ...... maybe this TSB is necessary ... ??
http://www.ft86club.com/forums/showthread.php?t=55551
Also, attached:
Old 01-25-2014, 04:14 PM   #7
DeLaRage
Also, attached:
sadly it didn't work. removed the positive and its still going down half way after clicking it to auto up or clicking up when it is already closed.
should i just take it back to the dealership and have them fix it ? i got the car this past monday. also I don't think it is the cold doing it to the windows because the windows go up and down like nothing
Old 01-25-2014, 04:32 PM   #8
humfrz
Well, DeLaRage, I'm out of ideas ....
Unless another forum member can come up with a fix, I reckon you should take it back to the dealer.
What fun ..... huh .....
Let us know how it turns out.
( ..... dang new fangled things ..... weren't nutten wrong with the window cranks .... )
Old 01-25-2014, 04:41 PM   #9
DoopaTroopa
Kato
DoopaTroopa's Avatar
Drives: The Black Beauty
FWIW whenever I reset the window, if the engine was off, the window would get stuck open/down. I had to have the car fully on to reset it. But one instance I had to disconnect the battery(negative) for about 15 minutes before trying again.
DoopaTroopa is offline   Reply With Quote
Old 01-25-2014, 05:25 PM   #10
Billylammerkins
Billylammerkins's Avatar
Drives: 2014 Firestorm Red FR-S 6MT
Did you try turning your car on and off again?
Billylammerkins is offline   Reply With Quote
Old 01-26-2014, 12:30 PM   #11
Belial86
Drives: 2013 FR-S MT firestorm
Make sure you hold the buttons down then up with the door shut
Belial86 is offline   Reply With Quote
Old 01-26-2014, 01:46 PM   #12
DeLaRage
I haven't tried with the car completely on. Maybe I'll try that when I get home. And I'll probably also try disconnecting the battery again to see if that works.
Yea I've been turning it on and off all week.
I've done that several times. But when I hold them up if I hold the driver side up too long it just goes back down to half way.
Thanks a lot for your help though !
Old 01-26-2014, 01:57 PM   #13
humfrz
Well, at least you gave it a good try.
I reckon the switch is most likely whacked out ....
The dealer should be able to get it working again.
Old 01-27-2014, 05:16 PM   #14
DeLaRage
So I magically fixed it! Lol. I was waiting in the car and I started playing with the windows. And they reset. Now it's working how it's supposed to.
Driver Side Window Rattle RiceCooker Issues | Warranty | Recalls / TSB 23 08-18-2015 10:20 AM
Driver side window clicks everytime it opens umpadupa Issues | Warranty | Recalls / TSB 10 10-25-2013 10:20 AM
driver side window scratch Celica00 Scion FR-S / Toyota 86 GT86 General Forum 13 07-31-2013 10:59 AM
Bass Rattles Driver Side Window Switches.... jadewbj Issues | Warranty | Recalls / TSB 14 05-19-2013 12:42 PM
Simple Shut Window Feature Not Working on Driver's Side Gimagination Issues | Warranty | Recalls / TSB 21 05-08-2013 11:59 AM
