Drives: 86
driver side window scratch
my driver side window makes a grind noise when I close and open my window and its leaving 2 vertical scratches. its going through the tint and everything. what should you do?
(=^・ェ・^=)
Drives: 2013 FRS, '08 GSXR 600
Back to the dealer she must go! Let us know what you find out so we know it's an isolated problem or wide ranged.
Drives: BRZ DGM Limited
Didn't someone else post recently that they had the same problem and the dealer found that some felt pads that protect the window as it goes up and down had fallen off??? I think so. Should be fixed under warranty
No rice, no life
Drives: 2013 Asphalt FR-S
whoo another recall in the near future!
Drives: Supercharged Golf Cart
Drives: 2025 BRZ, ex-2012 GT86
Same thing! Although just one scratch closer to the front of the window. Spoke today with the AD - they scratched their heads and said that they could have look but if it's not a problem under guarantee - it would cost me circa $180 for dissassembling the door and I would expect the entire day during WE lost - something which I can hardly afford. Will likely go for it during the first servicing though.
#8 | |
Drives: 2013 WRB BRZ Sport-Tech
Look where the scratches are and the look inside the window to see if they line up with the white plastic parts. |
Drives: FR-S [Hot Lava]
Mine might be doing this too. It is making a squeaking noise when I roll up the windows, and you can tell there is resistance there. Like it is working harder to push the window up. Seems to be worse when it's wet outside...
#10 | |
Drives: WRB BRZ
#11 |
I took the car to Subaru of Maple. They took very good car of the car and had it fixed in an hour. They will have to order parts which for me took a week.
#12 |
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
I have that too but only when wet.
#13 |
My driver's side sounds like it rubs/slams in the wet as well. Dry operation is normal.
The dealer should take care of it if that's what is causing your issue, though!
Amanda - 2013 Scion FRS (Raven)
#14 |
By now (6 months in use) my driver's side door window has 2 sets of fat and very noticeable scratches for the entire length of the window. On the outside. No tint but the window is severely scratched - looks very ugly
Brought it to the dealer claiming a warranty case and still waiting for the result of their e-mail exchange with Toyota... Curious to understand how many cars are affected with this issue - pls post here if you have similar problem. Thanks. |
| Driver Side Window Rattle | RiceCooker | Issues | Warranty | Recalls / TSB | 23 | 08-18-2015 10:20 AM |
| Driver side door handle | lordtakuban | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 06-19-2014 01:30 AM |
| 4 pin connector driver side | charley026 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 03-30-2013 01:27 PM |
| Driver window controls don't work | Hops Normal | Issues | Warranty | Recalls / TSB | 5 | 01-27-2013 08:35 PM |
| Teaking Tail light and Driver side passenger window auto down | feyrerm | Issues | Warranty | Recalls / TSB | 2 | 08-11-2012 12:32 AM |
