Old 01-11-2014, 11:01 PM   #1
Vincenttam
WtsTofu
Vincenttam's Avatar
Drives: Ultramarine fr-s
Dome light not turning on
So my Dome light isn't turning on anymore. I was trying to install some leds using a splitter supplied by diode dynamics. I notice one of the led boards had a positive wire not attached to the board so ima try to rma that. But afterwards my original leds that was working suddenly don't light up anymore when it's set to door. It only lights up when manually turned on. I put my stock bulb back in and same things. Only lights up on the manual switch but not door. Anyone knows whats up? Does my warranty cover this?
Vincenttam is offline   Reply With Quote
Old 01-12-2014, 12:35 AM   #2
humfrz
You may get some insight from this thread.
http://www.ft86club.com/forums/showthread.php?t=53629
humfrz
Old 01-12-2014, 02:51 AM   #3
Vincenttam
WtsTofu
Vincenttam's Avatar
yea i think im going to have to go through that guys route
Map/Dome Light Dis-assembly/Phastek Performance LED Dome Light F1point4 DIY (Do-It-Yourself) Guides 9 03-25-2014 09:39 PM
OEM Dome Light Bulb? ScionFR-S Interior Parts (Incl. Lighting) 4 12-09-2013 11:33 AM
DRL/dome light relay (15 pin plug) Zardoman Cosmetic Modification (Interior/Exterior/Lighting) 1 11-05-2013 04:24 AM
Replace Dome Light Zoomryder Cosmetic Modification (Interior/Exterior/Lighting) 6 04-09-2013 05:54 PM
