Old 08-23-2012, 12:18 PM   #1
Zoomryder
Replace Dome Light
Hello,
Can anyone give me some simple advice on how to remove the plastic shell? I know there are two small divets that look like I need to push in, but i tried and don't want to scratch or crack it. Is it pretty easy to do?
Zoomryder is offline   Reply With Quote
Old 08-23-2012, 12:23 PM   #2
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
I just replaced it last night, it was very easy. I used a flathead and pushed it into onto of the divets and leveraged it out a bit and then did the same to the other divet. Then I used my hands to pull the rest off. Piece of cake.
Books is offline   Reply With Quote
Old 08-23-2012, 12:37 PM   #3
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I had trouble with the lens myself I found it easier to pull out the whole assembly.
JoeBoxer is offline   Reply With Quote
Old 08-23-2012, 01:05 PM   #4
schoenberg
schoenberg's Avatar
Drives: 2013 Subaru BRZ, World Rally Blue
Turn the rearview mirror so that it is completely pointing forward lengthwise. Stick the screwdriver in straight up (Not at an angle.) Then push the screwdriver towards the windshield while applying upwards pressure. Do this for both of the rivets and then just pull it off with your hand.
schoenberg is offline   Reply With Quote
Old 08-27-2012, 05:59 PM   #5
StarsGarrador
Gangnam Style Guru
StarsGarrador's Avatar
Drives: Suzuki GSXF650, WRB BRZ
I had the same problem do I just sloped a knife in it an it popped right out with a bit of force. I didn't damage anything so just be gentle and apply a little force
StarsGarrador is offline   Reply With Quote
Old 04-09-2013, 01:22 PM   #6
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
I bent the plastic molding =/ easy to take out but the plastic is really soft, need to find a way to sand it back down
CamryDS is offline   Reply With Quote
Old 04-09-2013, 05:54 PM   #7
ThaBigUnit
Awesome Member!
ThaBigUnit's Avatar
Drives: 2013 Scion FR-S (Asphalt)
As Joe did, I had a tough time so I just took out the whole thing. Once you remove it, you just want unconnect the harness (which just pulls out) so it will be easier to handle, then there is just one phillips screw that needs to be removed to get to the light bulb. Super simple I promise!
ThaBigUnit is offline   Reply With Quote
Just replace door speakers? industrial Electronics | Audio | NAV | Infotainment 0 08-02-2012 02:57 PM
What to replace first to improve audio? garsh0p Electronics | Audio | NAV | Infotainment 1 06-21-2012 06:05 PM
How hard to replace BRZ Nav with aftermarket Nav? eikond Electronics | Audio | NAV | Infotainment 9 05-28-2012 07:52 PM
replace the Ford Navigation system? megancheung Electronics | Audio | NAV | Infotainment 1 03-22-2012 02:51 AM
