Old 02-02-2013, 01:15 AM   #1
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Map/Dome Light Dis-assembly/Phastek Performance LED Dome Light
20130201-PhastekDomeLightDIY-001 by VictorN07, on Flickr
It's been a while friends....
I know it's been done before, but I'm itching to use my new Olympus 12 F/2.0 with the OM-D. Therefore I'm back to do a silly DIY/Review for Phastek Performance's LED Dome Light. Thanks @Chris@Phastek for the professional service.
Let's get to it!
Product shots
Phastek incorporates dual pads for a total of 18 white LEDs
20130201-PhastekDomeLightDIY-002 by VictorN07, on Flickr
They come with double sided tape
20130201-PhastekDomeLightDIY-003 by VictorN07, on Flickr
The connector is spring loaded so I take it will fit a variety of cars
20130201-PhastekDomeLightDIY-004 by VictorN07, on Flickr
Tools:
Flathead Screwdriver
Blue masking tape
DIY
20130201-PhastekDomeLightDIY-005 copy by VictorN07, on Flickr
20130201-PhastekDomeLightDIY-006 copy by VictorN07, on Flickr
20130201-PhastekDomeLightDIY-007 copy by VictorN07, on Flickr
20130201-PhastekDomeLightDIY-008 copy by VictorN07, on Flickr
20130201-PhastekDomeLightDIY-009 copy by VictorN07, on Flickr
20130201-PhastekDomeLightDIY-010 copy by VictorN07, on Flickr
If you notice on the previous picture, the assembly has one side raised. Without correcting this, the pad on the drivers side will be further away than the other side. You can insert anything (box, cardboard, whatever) to level the playing field. I used a piece of mailing envelope and wedged it under the metal clip. Simple
20130201-PhastekDomeLightDIY-011 copy by VictorN07, on Flickr
20130201-PhastekDomeLightDIY-012 copy by VictorN07, on Flickr
20130201-PhastekDomeLightDIY-013 copy by VictorN07, on Flickr
20130201-PhastekDomeLightDIY-014 copy by VictorN07, on Flickr
20130201-PhastekDomeLightDIY-015 copy by VictorN07, on Flickr
Installed pictures
20130201-PhastekDomeLightDIY-016 by VictorN07, on Flickr
20130201-PhastekDomeLightDIY-017 by VictorN07, on Flickr
20130201-PhastekDomeLightDIY-018 by VictorN07, on Flickr
This picture has not been altered to show light output
20130201-PhastekDomeLightDIY-019 by VictorN07, on Flickr
Thoughts:
+ First off, it is very bright! I believe they are 5k color temperature
+ They fade to off like the OEM bulb
+ As shown above, it is very easy to install. Kit has everything
+ Dual pads are great for symmetry!
My questions:
+What do y'all think of the new camera setup?
F1point4 is offline   Reply With Quote
Old 02-02-2013, 01:20 AM   #2
Bmore_Raven86
Drives: Scion FRS Raven
nice!
Bmore_Raven86 is offline   Reply With Quote
Old 02-02-2013, 02:44 AM   #3
ninjasaurusrex
Drives: 2013 Raven Scion FR-S 6MT
what's that light next to the trunk release?
ninjasaurusrex is offline   Reply With Quote
Old 02-02-2013, 07:03 AM   #4
F1point4
Photo Specialist
F1point4's Avatar
AVOTurboworld drive by wire controller
Old 02-06-2013, 10:11 PM   #5
raptor87
Drives: 2013 DGM BRZ Ltd
how do you like the rear view mirror?
raptor87 is offline   Reply With Quote
Old 02-06-2013, 11:31 PM   #6
F1point4
Photo Specialist
F1point4's Avatar
It works, I love how it looks, and it might save like 1oz of weight. Unfortunately it doesn't add any substantial functional benefit.
Old 12-22-2013, 05:00 AM   #7
Vincenttam
WtsTofu
Vincenttam's Avatar
Drives: Ultramarine fr-s
If anyone doesnt mind me bumping this, i jsut recently installed some from diode dynamics, but it only came with 1 board =(. But how did you stick it to the right side?? It doesnt have a flat surface.
Vincenttam is offline   Reply With Quote
Old 12-22-2013, 11:50 PM   #8
Chimera
Drives: FRS
I made a small cardboard box and wrapped it with some scotch tape and slipped it into place to make my surfaces, if I recall correctly, I did both sides so the pads rest against the clear screen
Edit: in the pictures above they have a little box too wrapped in blue tape
Old 02-26-2014, 10:23 PM   #9
mateckz
Drives: 2013 Asphalt FRS
I am confused, i dont see where you can buy this kit at?
mateckz is offline   Reply With Quote
Old 03-25-2014, 09:39 PM   #10
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
This was super helpful for the Vicious LED kit. For anyone using that, black is your ground wire and red is power. Thanks.
Jyn is offline   Reply With Quote
Interior LED Dome Light Diffuser | DIY | 6X Brighter Dezoris Cosmetic Modification (Interior/Exterior/Lighting) 8 04-21-2013 08:59 PM
Replace Dome Light Zoomryder Cosmetic Modification (Interior/Exterior/Lighting) 6 04-09-2013 05:54 PM
Dual Color Dome Light boredom.is.me Electronics | Audio | NAV | Infotainment 2 01-13-2013 12:40 PM
