Old 05-26-2013, 12:51 PM   #1
Zardoman
Zardoman's Avatar
Drives: 2013 Subaru BRZ limited
DRL/dome light relay (15 pin plug)
Hi all,
I'm doing some exterior lighting for the BRZ and I can't seem to locate the DRL/dome lighting relay (that is a 15 pin plug) which suppose to be located under the steering column. anyone else know where this mysterious plug is?
based on the mechanic manual, its the D63 plug, named options connector..
please point me to the right direction, thanks!
Zardoman is offline   Reply With Quote
Old 11-05-2013, 04:24 AM   #2
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Originally Posted by Zardoman View Post
Hi all,
http://www.ft86club.com/forums/showthread.php?t=43422&highlight=twin+foot
here you find it!...let me know if pin are all populated....I am still crazy to understand where come from the loosing pin.
Trap63 is offline   Reply With Quote
Map/Dome Light Dis-assembly/Phastek Performance LED Dome Light F1point4 DIY (Do-It-Yourself) Guides 9 03-25-2014 09:39 PM
Replace Dome Light Zoomryder Cosmetic Modification (Interior/Exterior/Lighting) 6 04-09-2013 05:54 PM
Led dome light issue with heat Tiremonkey0824 Cosmetic Modification (Interior/Exterior/Lighting) 2 03-19-2013 07:46 PM
Dual Color Dome Light boredom.is.me Electronics | Audio | NAV | Infotainment 2 01-13-2013 12:40 PM
