Old 01-06-2014, 02:47 PM   #1
Frs32907
Drives: Asphalt grey, manual Fr-S
Can you run ecutek data logging on a samsung windows tablet
I was just wondering if this can be done using a windows tablet with usb ports and 32gb storage
Frs32907 is offline   Reply With Quote
Old 01-06-2014, 02:53 PM   #2
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Interested as well to find a good Windows tablet that can do tuning and data logging.
JDKane527 is offline   Reply With Quote
Old 01-06-2014, 03:35 PM   #3
wparsons
wparsons's Avatar
It should work no problem as long as you can install the EcuTek software on it. The new windows tablets are pretty powerful little machines.
flickr
Old 01-06-2014, 03:40 PM   #4
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
I run EcuTek on a Windows Surface, so as long as you have the USB ports (or port with a good splitter) and Windows 7/Windows 8 Pro it should work just fine.
mikalem is offline   Reply With Quote
Old 01-06-2014, 04:04 PM   #5
DJCarbine
Thupercharged
DJCarbine's Avatar
I'm using a dell venue 8 with a single USB port, split with an OTG cable + cheap 2 port hub... no problems
2013 FRS
Vortech V3 11psi
Old 01-06-2014, 04:06 PM   #6
swift996
swift996's Avatar
I was wondering this last night when I was looking at Win8 tablets. I assume it would only work on Windows 8/8.1 not the Windows 8 RT OS?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 01-06-2014, 04:38 PM   #7
DJCarbine
Thupercharged
DJCarbine's Avatar
Correct, it will only work on windows 8 not RT as far as I know.
Dell Venue 8 Pro is ~$230 depending on where you get them, one of the cheapest windows 8 tablets out there
2013 FRS
Vortech V3 11psi
Old 01-06-2014, 05:08 PM   #8
swift996
swift996's Avatar
Yeah, I want a 10". The ASUS T100 looks like a super bargain. I want a keyboard too, just don't know if I should wait a little while. I have a laptop that works fine.
Old 01-06-2014, 05:47 PM   #9
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
Not to hijack the thread. But just adding along the conversation of devices.
Asus just announced the Transformer Book Duet TD300 for CES today. It's one of those detachable Tablet/Laptop combos (Core i7 cpu etc) that does full Windows 8.1 and Android 4.2. You can switch to either OS on the fly. I think that might be a pretty sweet sounding deal there. Use Torque and other apps with Android and switch to Windows for your tuning solutions. It is on the bigger side though at 13.3 inches, but sounds like it could be a intriguing option.
JonAvalon is offline   Reply With Quote
Old 01-14-2014, 01:30 PM   #10
EcuTek
Drives: Toyota GT86
Hi guys. ProECU will run on any X86 tablet. It will not run on an RT tablet
EcuTek is offline   Reply With Quote
Old 02-09-2016, 10:30 PM   #11
tracerit
Drives: '13 SSM BRZ Limited 6MT
2 years later, anyone using a cheap tablet? This cheap tablet usually goes on sale at cowboom (bestbuy's clearance site) for $55, runs Windows 8/10 and is x86-64 bit.
http://www.cowboom.com/product/15897...XXDxJV9WLir3Ng
EDIT: looks like that tablet should work, a GT-R user is using a similar cheap tablet with the same CPU here: http://www.gtrheritage.com/topic/543...up-to-datalog/
tracerit is offline   Reply With Quote
OFT Data Logging and Exhaust Leak alexand3r Software Tuning 6 08-02-2019 07:02 PM
Data logging for noobs - OFT Shad0ez Software Tuning 18 11-07-2016 07:20 PM
Toyota Data Logging CAN for GT6 Luckrider Software Tuning 1 11-23-2013 02:03 PM
Ecutek Deltadash data logging advanced functions Yruyur Software Tuning 8 08-20-2013 01:10 PM
Ecutek Map Access, data logging Vs. obd2 sensor lbroskee Scion FR-S / Toyota 86 GT86 General Forum 3 01-06-2013 02:56 PM
