Old 01-06-2013, 02:26 PM   #1
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Ecutek Map Access, data logging Vs. obd2 sensor
Ecutek Map Access, data logging Vs. obd2 sensor with iOS app....are they essentially the same thing for reading data on the fly?
lbroskee is offline   Reply With Quote
Old 01-06-2013, 02:30 PM   #2
RYU
RYU's Avatar
Drives: really slow...
Is there an ecutek software version ported over as an iOS app? My understanding is you still need to run a windows emulator since the ecutek software is winos based.
Actually, if your iOS device doesn't have a USB isnt your only choice a bt obd2 dongle? Not even sure how that would work and all that latency ...
RYU is offline   Reply With Quote
Old 01-06-2013, 02:41 PM   #3
lbroskee
lbroskee's Avatar
let me expain that better. windows laptop with cable or a wireless OBD2 sensor that links to iOS using this sensor
http://www.ebay.com/itm/IOBD2-Wifi-W...item19d5f9858e
Old 01-06-2013, 02:56 PM   #4
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
I have what you are looking for and it is listed in the classifieds section here. Uses wifi to sync up with iPhone/Itouch. Make me a reasonable offer. I don't have an iphone anymore...
Edit:
Just re-read your message. You may want to PM one of the Pro-tuners with your question (FA20Club, Visconti, Perrin, etc...) It's all the same data however the amount of data and format is different. If you look at some of the more expensive setups that use the OT-2 Wideband sensors then one (me) could speculate that more data could be available to the OT-2. The bigger question may be "Why you want the data" vs "What data is present". Once one of the tuners know why then they may be able to address your question more accurately.
pixel67 is offline   Reply With Quote
OBD2 Port RJ_ AUSTRALIA 33 08-25-2016 10:25 PM
OBD2 Bluetooth Adapter Ravenlokk Engine, Exhaust, Transmission 49 09-04-2013 03:50 AM
ECU CAN access mhigham Engine, Exhaust, Transmission 5 11-16-2012 11:36 AM
obd2 engine sound app brichard0625 Engine, Exhaust, Transmission 4 09-25-2012 04:36 PM
Onboard Data Logging for XCross/Trackdays brzmaybe Tracking / Autocross / HPDE / Drifting 16 06-15-2012 07:03 AM
