Old 08-20-2013, 02:18 AM   #1
Yruyur
Yruyur's Avatar
Ecutek Deltadash data logging advanced functions
I see an option to start logging on wot or to start /stop logging via the defrost button. Anyone have any luck using these functions?
Sent from a Motorola DynaTAC 8000X
Old 08-20-2013, 11:50 AM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Nope, but I wouldn't mind that. Gets a little dangerous to try and look at the laptop to shut off logging after doing a 3rd gear pull.
Old 08-20-2013, 12:00 PM   #3
xxscaxx
Drives: 2013 SWP BRZ
you can use the insert/delete buttons on your computer - way better than trying to click but the defrost button is neat. I can try it out later on.
delete starts the map access, insert starts/stops datalogs
xxscaxx is offline   Reply With Quote
Old 08-20-2013, 12:05 PM   #4
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
Oooooh very nice to know. No more near-death experiences. :P
Nightbringer is offline   Reply With Quote
Old 08-20-2013, 12:11 PM   #5
xjohnx
Grip>Slip
xjohnx's Avatar
You could probably even get a USB button of some sort (whether it be a USB Keypad, or maybe something custom and remap using autohotkey)
Old 08-20-2013, 12:18 PM   #6
Nightbringer
Drives: Scion FR-S
Yeah that seems a lot more clever then leaning over/looking down at 100 MPH trying to use the damned touchpad :P
Old 08-20-2013, 12:27 PM   #7
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
Why not just hit the stop button after you'd ummm stopped? There is maybe 20 seconds of log from slowing down and it should be pretty easy for your tuner to tell the difference between WOT and fully closed.
Trashed675 is offline   Reply With Quote
Old 08-20-2013, 12:31 PM   #8
bgibbsunc
bgibbsunc's Avatar
Drives: Firestorm Scion FR-S
I just stop mine when I stop. Then edit it in excel. Pretty easy. sometimes I do a 3rd gear pull then turn around and do a 4th gear and I split them up after. Either way this seems like a really good option to use the defrost button.
FA20 club 60 trim + flex fuel
467 whp 356 ft lbs @ 19 lbs
Owner of Sidewinders Auto LLC.
San Antonio TX
bgibbsunc is offline   Reply With Quote
Old 08-20-2013, 01:10 PM   #9
canu_50
canu_50's Avatar
Drives: Scion fr-s
another great way to datalog is having a passanger in the car...
canu_50 is offline   Reply With Quote
Three letter word Search Functions? Beyer Subaru Site Announcements / Questions / Issues 3 04-24-2013 03:54 PM
ECUTEK Logging pdreams Engine, Exhaust, Transmission 5 02-05-2013 10:06 AM
Ecutek Map Access, data logging Vs. obd2 sensor lbroskee Scion FR-S / Toyota 86 GT86 General Forum 3 01-06-2013 02:56 PM
Onboard Data Logging for XCross/Trackdays brzmaybe Tracking / Autocross / HPDE / Drifting 16 06-15-2012 07:03 AM
