Old 05-10-2013, 05:13 AM   #1
JLMtm
Drives: FRS
Adding Coolant
Does it matter what kind of coolant to add as long as its mixed?
My Coolant level is right below then"low" line (when the car is cold)
I don't know If that's ok or not since it expands when it's hot?
JLMtm is offline   Reply With Quote
Old 05-10-2013, 08:10 AM   #2
gzpermadi
gzpermadi's Avatar
Drives: Toyota 86 Silver
How far below and when was the last time you had it filled?
Generally coolant level should not drop, but top up 1 liter in a year should be ok if you live in hot climate.
If you consume a liter in a month then there is something wrong, maybe a leak somewhere.
I would suggest to bring it to dealer.
gzpermadi is offline   Reply With Quote
Old 05-10-2013, 11:15 AM   #3
EK_Golfer
EK_Golfer's Avatar
Drives: 2013 Whiteout FR-S AT
Mine drops almost half way between the 'full' line and 'low' when cold. If it's below the 'low' line when cold I'd have it checked just incase.
EK_Golfer is offline   Reply With Quote
Old 05-10-2013, 11:28 AM   #4
frsjon
frsjon's Avatar
Drives: Whiteout Scion FR-S 6mt
for our cars i would suggest going with what is recommended from the factory and that is the blue coolant. the blue coolant comes pre-diluted so you dont have to add water, just top it off.
frsjon is offline   Reply With Quote
Old 05-11-2013, 06:15 AM   #5
JLMtm
Drives: FRS
Just a little below the low line
I've never added any since I've had it for 7 months now when it was full
When I went in for my first oil change I pointed it out to them
But they didn't top it off and marked it as ok so I don't know
It's just bothering me
Old 05-11-2013, 07:03 AM   #6
gzpermadi
gzpermadi's Avatar
Nah, I think you should be ok. When you see it after you drive the level will be between the low and full.
Just find the correct coolant, top it up a bit and monitor it.
I had a car with bad head gasket before and the car took a liter of coolant every month.
It's a good idea to check your fluids (oil, brake, coolant) every 2 weeks or at least once a month.
If it's getting worse mention it to dealer when you do the next service. Ask them to do the compression test or sniff test.
Blue Coolant Boosted2.0 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 108 07-12-2016 05:13 PM
FRS uses a lot of coolant? JLMtm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 124 01-23-2015 06:34 AM
Coolant Question boredom.is.me Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-15-2013 07:50 PM
Coolant Levels DriftEightSix AUSTRALIA 17 01-29-2013 09:19 AM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 12:03 PM
