Drives: AE86, 2x GT86, TE27
HKS Kansai carbon driveshaft coming - lighter than current carbon drive shafts
![]() No pricing, still in development (I checked again this morning) Weight is claimed to be 4.2kg, which is at least 1kg lighter than the current carbon driveshafts available. Will post when I know more. |
Drives: 2013 raven black fr-s
would love to have a ds this light, but not looking to spend 2k on this type of part atm.
Still, I'm liking where they are going. Thanks for posting this |
Drives: 2013 AT Firestorm FRS
How do you know it'll be 2k?
Drives:
My STX build thread
http://www.ft86club.com/forums/showthread.php?t=55616 |
Drives: 2005 Toyota Camry
+ Kansai.
http://www.kansaisv.co.jp/index.html http://www.kansaisv.co.jp/demo_car/p...odel=democar_1 Everything put on the car is $$$. -alex |
Drives: brZed
Man thats pretty
Carbon prop shafts for S2000 costs about 390000~450000yen so I think price should be around there.
Drives: Scion FR-S
Finally a company uses the correct weave.
Because compromise ®
Drives: Red Herring
Why is this the correct weave and by inference the others incorrect weave?
#10 |
Just a dude
Drives: Scion FR-S 2013
This is interesting. As I've tried a cf shaft let me explain what I hope this shaft has difference wise. I had a DSS shaft great piece btw. Acceleration and lack of slop was fantastic. No vibration or drive ability issues per say. Only I'm very sensitive "hearing wise" when I'd get to around 70-85mph there would be an air like noise, super hard to explain. Again no vibes etc but to me it was so different it was strange. Now I spoke in great length to some folks that had same concern again only hearing and they had their custom with microballs of styrofoam so like an acoustical filler if you will inside the shaft. I wonder if this shaft comes with any sort of coustic filler???
My other concerns is their glue and what rpm they're balanced to and how their balanced. Good find though gonna sub for updates thanks!!
#11 | |
Drives: Scion FR-S
Sent from my HTCONE using Tapatalk |
#12 | |
Drives: 2006 Cayman S, 2007 Outback 2.5i
For some reason (that I do not understand), many carbon driveshafts instead have the fibers wound very nearly circumferentially, at least at the surface of the driveshaft. This gives very little strength against a twisting load (but it would be great for a pressure vessel, like a composite scuba tank). They must have fibers in some other orientations internally as well, to give them the necessary strength, but even so, the fibers wound circumferentially at the surface are doing almost nothing aside from adding weight - for a driveshaft, you really want all of the fibers at or near 45 degrees (you could maybe make a case for varying the winding angle between perhaps 30 and 60 degrees in the various layers, but even that isn't really necessary). This also probably explains why they can make it lighter than other CF driveshafts. They also could be using a higher grade carbon - all CF isn't created equal. A standard carbon fiber might have a modulus (stiffness) of around 230GPa and a strength of around 3.5GPa, while a high modulus carbon will have a similar strength and a modulus of around 550-600GPa (so it's 2 or 3 times stiffer, but not a lot stronger). A high strength carbon fiber on the other hand might have a modulus around 300GPa (only a bit stiffer than the basic stuff), but an ultimate strength of around 6GPa or even a bit more (so nearly twice as strong as the basic carbon fiber). Of course, the high stiffness and high strength carbon fibers are a lot more expensive than the ordinary carbon, but using them can significantly improve the strength and stiffness (or reduce the weight for the same strength and stiffness) compared to a component made with basic CF. |
#13 |
Drives: 2013 WhiteOut FR-S
Sick looking CF DS, this will be easily $2k or higher like others said HKS Kansai
Sent from my iPhone using TapatalkfQ
2013 Scion FR-S whiteout 2012 Porsche Panamera S carbon grey 2008 Range Rover Sport SS black - sold 2004 BMW M3 alpine wies - sold |
#14 | |
Señor Member
![]() Could the circumferentially wound carbon be a safty measure, to hold the shaft together better at high rpms?
1974 TA22 Celica
2013 86 GT |
| DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft | F1point4 | DIY (Do-It-Yourself) Guides | 67 | 04-17-2021 05:21 PM |
| We have carbon drive shaft, yno carbon axles? | diss7 | Engine, Exhaust, Transmission | 2 | 10-26-2013 09:40 PM |
| New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft | Evasive Motorsports | Engine, Exhaust, Transmission | 1 | 09-24-2013 02:27 PM |
| Are dry carbon fiber front 1/4 panels lighter than OEM? | Superhatch | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 05-27-2013 03:47 AM |
| HKS Kansai - Carbon Fiber lip spoiler | Citrus | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 02-10-2013 11:02 PM |
