Drives: 2013 Asphalt FRS
Would this work to trick the tps sensor
Snow has hit and I have a set of 16" wheels and snow tires from my previous car. From reading all the forums it seems the frs is capable of driving with snow tires and a little extra weight. People are experiencing the TPS light coming on with aftermarket wheels. Since the tps is sensing all its information from the ECU....My question is what if I simply kept the set of stock wheels and tires in my car as I drove. It would add the extra weight and the ECU would still read it and not throw on the TPS light. Any thoughts?
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
I drove 350km with the stock wheels/tires/tpms sensors in the back and the light did not come on.
Drives: 02 maxima 6spd sold 2013 frs daily
It'll work . The car will think the tires are in the car
Sent from my HTC6500LVW using Tapatalk |
Thanks fellas for quick response
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Buddy of mine did that and his car lit up like a Christmas tree. Maybe it's a hit or miss? I don't know much about it, maybe you'll get lucky?
If the sensors are in the car and seeing enough pressure the light will definitely stay off, you *could* build a small PVC chamber and put all four sensors in it to keep the light off.
That said, driving around with all four tires will mean your back seats are always useless.
#7 | |
The SquadWhisperer
...You mean there exists a time when the rear seats aren't useless....? |
| The Following 3 Users Say Thank You to Thorpedo For This Useful Post: |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
you can swap the TPMS on your 16's if you want. thats what i did. my winter wheels have my STOCK tpms on them. or you can buy new sensors that piggy back off the current sensors. its fairly simple.
as far as needing weight in the car for snow, regardless its light. as long as you have a good tire you will be okay, i was able to drive through a few feet of snow last season with my snow tires. this year i doubt i'll get away with that, as my car is too low. |
#10 |
Drives: IB '05 E46 M3 ZCP
The way I've been beating the annoying TPMS light w/ my aftermarket wheels is
I have my stock wheels w/ the TPMS sensors still in them sitting in the garage fairly close to where I park my car. Now if I leave my car on and idle for just a little, I trick the system into thinking I still have the stock wheels on (since theyre within detectable distance from the car). Keep in mind the TPMS warning light will illuminate once you reach near 100 miles (or around there havent really payed too much attention to know the exact mileage before it gets tripped to come on again). Obviously it wont work if your taking a road trip or going cross country. Works for me & keeps the annoying light off.
![]() '05 Interlagos Blue |
#11 | |
Señor Member
Drives: white BRZ 6MT
#13 |
the tuna, no crust.
no i mean like 2 ft DEEP. car had no problems until i came to a full stop. then it was a problem
#14 |
Drives: 2013 FR-S Argento
Family of four: 6'2" (me), 5'11" (wife), tall 8 year old, skinny 6 year old, we take the FR-S everywhere with no problems.
| is the front o2 sensor a wideband sensor? | mad_sb | Engine, Exhaust, Transmission | 19 | 12-13-2015 03:20 PM |
| Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? | Acree | Engine, Exhaust, Transmission | 2 | 08-26-2013 07:39 PM |
| Trick to restrat on last map used on ecutek | Mars2 | Engine, Exhaust, Transmission | 23 | 04-05-2013 05:30 PM |
| Delivery fee dealership trick | oldpueblo | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 10-18-2012 10:29 PM |
