Old 08-26-2013, 06:20 PM   #1
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output?
Does anyone know what type of the sensor the stock CAS is?
Does anyone have any pictures of the stock CAS wheel?
Does anyone know what type of waveform the sensor outputs?
I've been trying to pour through online technical PDFs and can't find an answer to this question. If no one on here knows then I'm just going to have to put an o-scope on it.
Acree is offline   Reply With Quote
Old 08-26-2013, 06:36 PM   #2
arghx7
Drives: car
See attached TSB, it has this waveform in there:
It sure looks very similar to the EJ25 crank angle sensors. See STI service manual excerpt below:
I would characterize it as a variable reluctor sensor with 3(?) missing teeth, basically the 2-tooth gap is one reference window and the 1-tooth gap is another.
File Type: pdf BRZ TSB 11-130-13 CAM POSITION SENSOR.pdf (1.73 MB, 5170 views)
arghx7 is offline   Reply With Quote
Old 08-26-2013, 06:39 PM   #3
SkullWorks
Drives: SSM LT MT BRZ
how hard did you really try?
it is in the FSM.
SkullWorks is offline   Reply With Quote
O2 Sensor ? grostoine Engine, Exhaust, Transmission 4 02-21-2016 10:20 PM
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 02:20 PM
FA20 vs EJ20 crankshaft Draco-REX Engine, Exhaust, Transmission 66 02-19-2014 08:49 AM
FS: Stock Wheels+Stock Tires+TPMS sensor Pin Flare Wheels and Tires 1 03-26-2013 11:07 AM
Stock O2 Sensor d1ck Engine, Exhaust, Transmission 1 07-11-2012 07:16 AM
