Old 11-01-2013, 03:57 PM   #1
xDanger_208x
xDanger_208x's Avatar
Drives:
My cheaper/simpler tranny mount
So I installed the KartBoy shift bushing, Whiteline bushing insert and Mtec shift springs. While installing the bushing insert, I noticed the slop in the center carrier bolt that goes through the bushing.
I've seen some solutions on the market for this, but I decided to fix it myself.
It's just a simple tube I machined out of some aluminum round stock I had at the shop.
I will say.. these simple mods have drastically improved shifting and the over all "feel". So much so, that I had a short shifter but decided not to install it and sent it back. The $200+ will be better spent elsewhere.
xDanger_208x is offline   Reply With Quote
Old 11-01-2013, 05:33 PM   #2
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
What are the dimensions of this piece? (ID, OD, length) I'm thinking there might be an off-the-shelf bushing at McMaster-Carr that would work, depending on the size.
neurokinetik is offline   Reply With Quote
Old 11-01-2013, 05:38 PM   #3
xDanger_208x
Drives:
I can't remember the length, but it's 20mm ID, 28mm OD
Old 11-01-2013, 07:47 PM   #4
neurokinetik
http://www.mcmaster.com/#standard-sl...arings/=p71rzu
Looks like there are four possible options, the most expensive of which is still under $5
SAE841 material
6658K47 (16mm long, might be too short, $2.84)
6658K48 (20mm long, $2.88)
Alloy 932
7811K47 (16mm long, again, might be too short, $4.67)
7811K48 (20mm long, $4.74)
Personally, I'd just grab a 7811K48 and give it a shot. The alloy 932 seems to be the better material, and 20mm long is probably the right length. If it's too long, cut or grind it down a little.
Old 11-01-2013, 09:24 PM   #5
Mr.
Supra Senior Member
Mr.'s Avatar
Drives: AE86 & BRZ
question. Stiffing the transmission does it effect the stress on the engine bay / chassis? I read somewhere that because you are stiffing up one part of the car it creates stress points on other areas. This looks like a nice DIY find.
Build Thread
YouTube Channel
IG - Fwankyhong
Subscribe
Mr. is offline   Reply With Quote
Old 11-01-2013, 09:25 PM   #6
xDanger_208x
Drives:
It might/might not. I'll be replacing the motor mounts soon anyways.
Old 11-03-2013, 02:04 PM   #7
ramiram1984
Drives: 2016 STi DGM
The Perrin one is pretty inexpensive
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
A simpler spring/strut install DIY -- no compressor needed jeebus DIY (Do-It-Yourself) Guides 120 01-17-2023 09:28 AM
*Raceseng Tow Hook w/ Go Pro Mount Built In Front/Rear Mount -fteightysix* 86SPEED Exterior Parts - The Rest 2 08-20-2013 01:37 AM
Perrin Tranny mount cruise speed whine? Kartboy be the same? thoughts... OICU812 Engine, Exhaust, Transmission 18 08-19-2013 04:00 PM
DIY: Making a GoPro camera mount with a GrimmSpeed front plate mount PMok DIY (Do-It-Yourself) Guides 2 06-11-2013 10:58 AM
Will installing sub frame and tranny mount bushings cause premature wear? brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 03-16-2013 03:56 PM
