Old 03-16-2013, 01:04 PM   #1
brillo
Drives: 2013 Firestorm FR-S
Will installing sub frame and tranny mount bushings cause premature wear?
On the engine and diff bushings? Will it lead to less wear due to less movement ?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 03-16-2013, 01:29 PM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
A tranny mount could cause wear on the engine mounts as the engine and tranny are hard mounted to each other.
Old 03-16-2013, 01:37 PM   #3
brillo
I'm specifically referring to the white line tranny insert, which may not be as stiff as true replacement tranny mounts
Old 03-16-2013, 04:56 PM   #4
Calum
That Guy
I haven't used it yet, but looking at the design I think you'll be fine.
DIY - Whiteline Rear Crossmember Mount Insert Bushings F1point4 DIY (Do-It-Yourself) Guides 91 01-17-2021 03:23 AM
Let's Discuss Tire Wear SkitterSkotter Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-15-2014 12:35 AM
Clutch wear? Pakjk89 Engine, Exhaust, Transmission 102 04-12-2012 08:21 PM
wear your seatbelt... bofa Off-Topic Lounge [WARNING: NO POLITICS] 17 07-16-2011 05:25 AM
