Old 08-18-2013, 11:06 PM   #1
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Perrin Tranny mount cruise speed whine? Kartboy be the same? thoughts...
So here is gig..
Got the Perrin tranny mount and shift bushing. Anyhow performance wise great for sure. On highway at 65-70mph or 110-114kms there is a "faint" whine, when you accelerate steady it goes away, when let of fast not so audible. I'm convinced its the tranny mount itself and of course I expected nvh to be clear.
Anyhow the stop and ramp up nvh is no issue for me it's the faint whine cruising long distance on highway that is tad irritating even with tunes up I can hear it. The tone is faint but most audible at speed limit "of course" :/
Would going from Perrin Tranny mount "metal" to a Kartboy 85 durometer Poly/Rubber mount eliminate the cruise speed whine I'm hearing?
Logic tells me it should but then again it's a completely different style of tranny mount to. If anyone has done this test or been in this car with a Kartboy please share your experience with how you feel about this or what you hear as well..
In end ifnIncant find a solution ill yank it and go back to stock, but honestly I like the improvement in feel in the car performance wise.
Old 08-18-2013, 11:16 PM   #2
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
There was a noticeable increase in NVH when I installed the Perrin transmission support. It got pretty out of hand when I installed the whiteline differential mount. Try loosening your driveshaft bearing mount and retighten it after letting it drop to see if it helps. It helped reduce the NVH I was experiencing.
I also have the Battleversion subframe bushings installed. For what it's worth, I was noticing clunking from the front driver corner of my car, until I installed Turn in Concepts solid steering rack mounts.
Sent from my SCH-I535 using Tapatalk 4
JDKane527 is offline   Reply With Quote
Old 08-19-2013, 01:30 AM   #3
OICU812
Just a dude
OICU812's Avatar
Ok so to clarify you started with Perrin, then tried Whitelines or ran both same time? I know kart boys is same design as whiteline but a hard rubber vs WL plastic.
Good tip on carrier ill look into that.
This is 100% bearable around town and honestly its not bad on hwy but it's the steady faint whine at cruise speed on longer trips I'm not liking.
Old 08-19-2013, 01:37 AM   #4
JDKane527
JDKane527's Avatar
I only tried the perrin transmission stiffener for transmission mount. Whiteline is only installed on the rear differential. Totally separate but modifications done to the driveline.
Old 08-19-2013, 01:39 AM   #5
OICU812
Just a dude
OICU812's Avatar
Oh ok sorry I thought you meant the WL tranny insert as well as I've heard of guys doing that. I should mention yes I have the WL subframe bushings but no diff mount etc...
Did you end up removing the Perrin tranny mount or just learned to live with whatever nvh you have now?
Old 08-19-2013, 01:45 AM   #6
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
It's the immortal performance vs comfort decision.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 08-19-2013, 02:08 AM   #7
Nardi330
Nardi330's Avatar
Drives: 86
i have cusco tranny mount, Perrin rear shift mount, WL diff mount inserts and WL rear subframe inserts. along with STI engine mount, there isn't a lot of NVH increase but there is definitely more sound but they are not too audible over my Perrin header back....
Nardi330 is offline   Reply With Quote
Old 08-19-2013, 02:22 AM   #8
OICU812
Just a dude
OICU812's Avatar
Exactly ...
Old 08-19-2013, 02:23 AM   #9
OICU812
Just a dude
OICU812's Avatar
Interesting. Is the cusco tranny mount a solid T shape like Perrins? I ask this as there are no good pictures showing it really..
Old 08-19-2013, 03:12 AM   #10
OrbitalEllipses
Drives: Attitude
The Perrin and Whiteline transmission mount inserts are both polyurethane.
Your google-fu is weak my son.
Old 08-19-2013, 03:40 AM   #11
OICU812
Just a dude
OICU812's Avatar
Perrin one is a T shape like stock only fills gap, WL one a totally different one where it surrounds like Kartboy. Now you're saying this Perrin T Shape one is poly?? Sure felt like metal to me?.....I'm speaking of tranny mount not shifter bushing here... Shit maybe its too late and I'm not making sense lol..
Thx for pic on cusco one. Don't quite understand that one in comparison to others. I'm sure if seen and was mounting it in would make more sense to me.
Old 08-19-2013, 03:45 AM   #12
JDKane527
JDKane527's Avatar
Pretty sure the perrin piece is metal. The cusco both fills in the void in the lower region that kartboy and whiteline pieces fill. It has a short metal tube that fills in the void the perrin piece fills.
Old 08-19-2013, 03:51 AM   #13
OICU812
Just a dude
OICU812's Avatar
I get it now the cusco fills top and bottom spaces. Thanks.
Old 08-19-2013, 02:58 PM   #14
OrbitalEllipses
Drives: Attitude
OIC, you're were talking about two different pieces...but I forgot Perrin doesn't have a trans mount INSERT. The sentence should have been: "Whiteline and Kartboy trans mount inserts are both polyurethane." The Perrin/Cusco/Forced Fab pieces are identical in function while the Kartboy and Whiteline inserts are identical in function; they serve different functions as you observed.
Mis-communication on both our parts.
BC Racing, Whiteline Sway Bars, Kartboy Rear End Links, Carbotech, DBA@ OAKOS OAKOS Automotive Brakes, Suspension, Chassis 226 01-19-2015 01:46 PM
Whiteline - Perrin - Kartboy - KW - RCE goodies! Muller Performance Brakes, Suspension, Chassis 63 09-21-2013 10:32 AM
Looking for feedback and thoughts on Kartboy and TWM short shifters for our cars OICU812 Engine, Exhaust, Transmission 2 07-25-2013 05:02 PM
Perrin or Kartboy pulley? jordanrw260 Engine, Exhaust, Transmission 55 05-12-2013 12:08 AM
Will installing sub frame and tranny mount bushings cause premature wear? brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 03-16-2013 03:56 PM
