Old 10-17-2013, 08:10 PM   #1
autoCAR
Drives: 5/2013 scion frs
HELP kw coilover top hat install problem
this is prob an obvious thing, but I'm putting my kw coilovers on n I gotta swap the stock top hats on. I can't get the bolt to thread on more than a tiny bit coz the strut keeps spinning what so I do?
I atructions say take the rubber out of the to hat? Wtf?
autoCAR is offline   Reply With Quote
Old 10-17-2013, 08:11 PM   #2
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
If the shaft is spinning you can use an allen key to hols it in place and a open wrench or socket to turn the nut.
Circuit Motorsports is offline   Reply With Quote
Old 10-17-2013, 08:14 PM   #3
d1ck
Drives: Black 2013 FRS
I think the KW's have a 7mm hex on the end of the shock shaft. You need to use a pass through socket driver for the top nut while using a 1/4" Drive 7mm ratchet to hold the shaft in place.
d1ck is offline   Reply With Quote
Old 10-17-2013, 08:17 PM   #4
cnk
Drives: '13 DGM BRZ Limited
You can also use a strap wrench to hold the shaft in place.
cnk is offline   Reply With Quote
Old 10-17-2013, 08:34 PM   #5
autoCAR
thankyou all. In going to get one of those wrenches now. Ugh I wish I knew this before ripping out my struts
Old 10-17-2013, 08:37 PM   #6
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
I hope you did not use impact gun. yeah this is the stuff that many failed to mention.
hanabie is offline   Reply With Quote
Old 10-17-2013, 08:52 PM   #7
djdnz
1337
Drives: 2013 BRZ WRB S/C
You don't need to get a special wrench. Put a socket on the nut, use vice grips to grab the socket. Then use an allen key to hold the shaft from spinning. Now turn the vice grip.
djdnz is offline   Reply With Quote
Old 10-18-2013, 12:16 AM   #8
autoCAR
the kw's don't have an Allen key on top, a 9mm socket fit over it, but my 90* wrenches didn't fit. Literally only way yo tighten the top was to use those open end socket wrenches, 40 bucks at Lowe's -__-
I got another ?, dnt wanna start another thread. I noticed my one rear coil, (other was in by that point) made a noise, sort of a ping when I flipped it upside down, like something was sliding inside, I took a vid I'll upload tomorrow. Please don't tell me that that is something wrong coz I dnt wanna take these out again to send them out for warranty work.
Old 10-18-2013, 10:23 AM   #9
djdnz
1337
Woops! Sorry I have RCE Tarmac Zeroes, which are based on the KW V1. I wrongfully assumed they were the same, but forgot you have an adjustment knob on the top. The V1/T0's have an allen key on top.
Was the sound metallic? Could it have been the plastic cover that was sliding up and down?
Old 10-18-2013, 10:54 PM   #10
autoCAR
I didn't upload the video yet, I've been swamped all day. (on cell now), it sounded similar to those whistle sound maker toys, that squeel when U turn it upside down. Il upload sometime this weekend
Old 10-18-2013, 10:55 PM   #11
autoCAR
the rear end doesn't seem to be making any noises, or I just haven't hear yet. I'll keep this thread posted
Revworks UEL Install Problem Admired Engine, Exhaust, Transmission 3 10-07-2013 10:37 PM
boot lip install problem derka-derka AUSTRALIA 1 09-24-2013 12:10 AM
Subwoofer/Amp install problem evanmd Electronics | Audio | NAV | Infotainment 4 07-22-2013 03:50 AM
HKS Coilover install gtauto AUSTRALIA 16 04-21-2013 07:37 AM
Problem Headlights after HID Install imravenit Cosmetic Modification (Interior/Exterior/Lighting) 2 09-30-2012 08:18 AM
