Old 09-29-2012, 10:05 PM   #1
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
Problem Headlights after HID Install
hey my fellow gt86 owners!!
im not sure if im the only one here but id like to know if anybody else is having this problem..
so after an install of a HID kit (both low and high beam).. i will update for a specific model but anyways..
on daylight when the headlights are off and the car is only running on DRL .. only of the lights turns on (high beam lights) i double check all the connections for the high beam hid kit and there all intact and nothing is loose.. but when i mess around with the ebrake handle by putting it up and down while sitting inside the car and i can see the reflection of the lights it helps to make the other light turn on.. now theres no consistency which one is not working vice versa.. im not sure if i should just remove the DRL relay.. cuz this is somewhat annoying it makes me feel like i have a ghetto broken car.. when your driving around with only one high beam on (DRL lights) ...
anybody else?
imravenit is offline   Reply With Quote
Old 09-29-2012, 10:23 PM   #2
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Dont buy bing bong hid's? /racist comment
TouchMyHonda is offline   Reply With Quote
Old 09-30-2012, 08:18 AM   #3
Hardrock4445
Hardrock4445's Avatar
if you remove drl relay high beams will not work. Buy a horn relay, replace drl relay with purchased horn relay. Will delete drl function and high beams will still be functional. Should do you the trick.
Hardrock4445 is offline   Reply With Quote
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 07:07 PM
A problem i've had with my sunroof. Asterisked Accolade Other Vehicles & General Automotive Discussions 10 08-28-2012 03:58 PM
ABS Problem chrislee2423 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 07-09-2012 04:06 PM
anyone with this problem? debs0712 Scion FR-S / Toyota 86 GT86 General Forum 2 06-30-2012 10:17 AM
