Old 10-07-2013, 08:07 PM   #1
Admired
Drives: 2013 Scion FRS
Revworks UEL Install Problem
Anyone who has installed the revworks UEL can you assist me on something. As you may know one of the 3 nuts on the drivers side collection pipe can be tightened but not all the way as the angle of the pipe interferes with tightening the nut tightly. The angle of the 3/8" extension and 14mm socket won't all it to catch the nut correctly. Has anyone ran into this problem if so what did you do? I took it for a test ride and there was no leaks or sounds that I could distinguish but I want to tighten it again to make sure i just don't know how. Im thinking a swivel socket would work but Im not sure
Admired is offline   Reply With Quote
Old 10-07-2013, 08:30 PM   #2
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Don't fully insert the extension into the 14mm socket, just enough to make contact. This will give you some extra room so the stud can go into the 3/8 hole of the socket.
Edit:When I say 'extension', I was inferring a wobble extension (aka u-joint).
SloS14 is offline   Reply With Quote
Old 10-07-2013, 09:22 PM   #3
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Wobble extensions bro
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Old 10-07-2013, 10:37 PM   #4
Argento_FR-S
Drives: Scion FR-S
I used an open ended wrench and stuck it between the pipes onto the nut. Then ran an allen wrench through the closed end and twisted. Luckily it's a low torque requirement for the manifold nuts.
Argento_FR-S is offline   Reply With Quote
Blown strut or other problem after spring install? f0rge Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 01-12-2016 03:26 PM
JDL UEL vs. Revworks UEL brzadmir Engine, Exhaust, Transmission 23 01-21-2014 09:02 PM
boot lip install problem derka-derka AUSTRALIA 1 09-24-2013 12:10 AM
Subwoofer/Amp install problem evanmd Electronics | Audio | NAV | Infotainment 4 07-22-2013 03:50 AM
Problem Headlights after HID Install imravenit Cosmetic Modification (Interior/Exterior/Lighting) 2 09-30-2012 08:18 AM
