Old 09-27-2013, 05:13 PM   #1
muffinz
Drives: 2013 DGM BRZ Ltd
Door Circuitry Problem?
Hi Everyone,
I tried searching for anyone that has had a similar problem and couldn't find anything...so here's my issue:
History: My windows froze a couple times last winter (probably due to snow melting and freezing inside) but since then they have had no issues (~8 months of normal operation)
Present: I replaced every interior bulb with LEDs, including the door courtesy lights.
Issue: when I FIRST open my door in the morning, or after the car has been sitting for a while (ie "cold"), the driver side window makes a sort of "POP" noise. It sounds like a metal-glass impact. I checked the seals all along the window and everything looks fine. I began noticing this about 1 week after installing the LEDs. It also only seems to happen when I open the door in a normal fashion. If I open the door gently, it doesn't make this noise.
Theory: I know this could be totally wrong, but is it possible that the switch to LEDs has caused a current imbalance in the door circuitry causing the window motor to pull extra power and jerk the window open or not open it fast enough?
Any advice? I checked out the BRZ wiring diagram online to see where the courtesy light is located in the circuit but you need a plotter printer and 4'x8' paper to make any sense of that.
Help is greatly appreciated! I think in the mean time I will switch back to the incandescant bulbs and also test the passenger side window.
Thanks guys!
muffinz is offline   Reply With Quote
Old 09-30-2013, 04:44 PM   #2
muffinz
half bump half more info:
I didn't put the incandescant bulbs back in...but today I had the door opened and then pushed the button on the door sill that tells the motor to raise / lower the window...and it made the noise while the door was open.
So this rules out collision between glass and a non-door component of the car.
Anyone have any ideas? could the glass be off the track?
Changing out the door/courtesy lights - problem mikalem Cosmetic Modification (Interior/Exterior/Lighting) 19 02-10-2014 09:39 AM
DRL problem benlaz88 Scion FR-S / Toyota 86 GT86 General Forum 23 09-19-2013 09:58 PM
E85 problem asher187 Engine, Exhaust, Transmission 4 08-27-2013 11:37 PM
TRD door stabilizer and door sag.... Tromatic Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 05-25-2013 10:16 AM
DDM HID Problem LinknLog Cosmetic Modification (Interior/Exterior/Lighting) 18 04-11-2013 01:43 PM
