Old 11-10-2012, 03:34 AM   #1
LinknLog
Drives: Whiteout FR-S
Question DDM HID Problem
So I installed the 35w 6K DDM tuning kit and it looks great. However, when turning on my headlights the passenger side bulb does not turn on on the first try. I have to flick my lights on and off 2-3 times before they come on. Will check connections tomorrow but has anyone dealt with this problem or have any idea of what might be going on?
LinknLog is offline   Reply With Quote
The Following User Says Thank You to LinknLog For This Useful Post:
wawro569 (11-10-2012)
Old 11-10-2012, 03:51 AM   #2
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
bad ballast
86_ZN6 is offline   Reply With Quote
Old 11-10-2012, 11:57 AM   #3
wawro569
Drives: 2013 Scion FR-S MT
Ive had this same exact problem, passenger side too, if i turn them on with the engine off they go on like they should, but once i turn the engine on while the lights are starting up the passenger side starts flickering rapidly until its fully warmed up and sometimes it just goes out.
wawro569 is offline   Reply With Quote
Old 11-10-2012, 12:30 PM   #4
wbradley
Sarcastic SOB
wbradley's Avatar
Bad ballast or faulty connection. Eliminate the connection possibility by swapping ballasts right and left.
I had a ballast just go on me after a few weeks from my vendor on eBay from Quebec. They immediately sent me a replacement.
I suspect the cheap HID packages are not so reliable. But, for the price they look and perform the same normally, so worth trying.
It helps if the vendor backs their product.
Old 11-11-2012, 12:23 PM   #5
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
probably a cheaply made ballast, how much did you pay for them ? go with a high quality HID and you wont be disappointed
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 11-11-2012, 12:56 PM   #6
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
luckily, the DDM guys tend to stand behind their cheap product and usually offer an rma/partial replacement free of charge. Just give them a call.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
Old 11-11-2012, 01:22 PM   #7
KI_ZN6
KI_ZN6's Avatar
Agreed! I would definitely go with something of high quality as you end up spending less when investing in a quality HID conversion kit.
KI_ZN6 is offline   Reply With Quote
Old 11-11-2012, 03:19 PM   #8
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I have yet to see a quality hid kit. Quality is phillips, denso, matsushita, bosch etc..
Rayme is offline   Reply With Quote
Old 11-11-2012, 04:05 PM   #9
ScionFR-S
ScionFR-S's Avatar
Try out HID_Powerhouse's products, they are the best i have tried thus far. no flickering and have a great projectile
Old 11-11-2012, 04:31 PM   #10
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
If you want to be sure it's the ballast you could first swap the bulbs and test.
If the problem stays on the same side then you know it's likely the ballast.
I've seen bulbs do things like this too.
CircuitJerk is offline   Reply With Quote
Old 03-18-2013, 10:21 PM   #11
efactor84
efactor84's Avatar
Drives: 2015 Scion FR-S
Had the same issue with the H11's flickering, but it took away my problem from having to run the daylight running lights all the time. I haven't face any issues putting them in brights both work at the same time with no flick, but one will flick on one side of the other when you run daylights. So, I just let my ebrake down slowly so neither will flick on either side, which will have both remaining off.
efactor84 is offline   Reply With Quote
Old 03-18-2013, 10:46 PM   #12
Squishy86
Squishy86's Avatar
Drives: Your Car
I live a couple a miles from DDM. I've used 3 of their kits and I've had problems with all of them from flickering to bad connections. In honesty, you get what you pay for ($35). They will replace anything faulty in regards to ballasts so if you really want to deal with it rather than getting quality kits, then you can do that.
Sent from my SGH-I777 using Tapatalk 2
Squishy86 is offline   Reply With Quote
Old 03-20-2013, 01:01 AM   #13
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
yeah ddm is cheap but ive swapped out muuultiple ballasts and bulbs they do a great job of backing up their product
eddieEndo is offline   Reply With Quote
Old 03-20-2013, 12:51 PM   #14
sidnacious
sidnacious's Avatar
Drives: Argento FR-S
I would just go down to the shop and talk to them. I had a problem with mine, they helped me troubleshoot and fix the problem. Very nice people.
sidnacious is offline   Reply With Quote
ddm tuning, hid, problem
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 07:07 PM
A problem i've had with my sunroof. Asterisked Accolade Other Vehicles & General Automotive Discussions 10 08-28-2012 03:58 PM
ABS Problem chrislee2423 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 07-09-2012 04:06 PM
anyone with this problem? debs0712 Scion FR-S / Toyota 86 GT86 General Forum 2 06-30-2012 10:17 AM
