Old 05-13-2013, 08:19 PM   #1
Tromatic
TRD door stabilizer and door sag....
I've never had a car with frameless doors. Is "door sag" a real issue? I could not care less about the supposed handling bennies of the TRD door kit, but if it does indeed provide support and longevity to the doors and hinges it's an easy decision.
OTOH, wouldn't making one end of the door stiffer than originally designed put an extra load on the hinges as the car flexes?
Originally Posted by Nezz View Post
I'm putting the door stabilisers in because I've owned plenty of cars with frameless windowed doors (Toyota TA46 Celica, RA40 Celica, RA60 Celica, Nissan Silvia S13) and a few with framed windowed doors (Nissan Gazelle S12, Accord, few others) and dealt with a few more (AE86s for instance) and frankly, frameless windowed doors sag. They sag like a bitch. The hinges wear out-- Then the catches misalign and it's an arse bastard to close the doors... Anything that will help stop them twisting against the hinges? I'm all over that.
Tromatic is offline   Reply With Quote
Old 05-13-2013, 08:35 PM   #2
FnFast
Doctor
FnFast's Avatar
Drives: Fast
Now... sorry for a slight thread jack, but the BRZ already has those stabilizers correct? If the BRZ has them, I would invest in some stabilizers if I were you.
Jeremy Clarkson "If you go though the Pearly Gates, backwards, in a fireball, that's a cool way to die!"
2013 White Pearl BRZ Limited 6MT - 15% Tint, Debadged, HIDPowerhouse LED Interiors and Dome
FnFast is offline   Reply With Quote
Old 05-13-2013, 08:36 PM   #3
Burrcold
Drives: Subaru BRZ Limited
?? Huh
Old 05-13-2013, 10:17 PM   #4
wparsons
wparsons's Avatar
The window frame does nothing to support the door at all, so it having frameless windows means nothing.
LOTS of cars (911's, most subarus, even 1st gen neons) have frameless windows and none of them have issues with hinges.
I would imagine that the doors aren't twisting at all, but the car around them does with age and these stabilizers aren't going to help that at all.
flickr
Old 05-14-2013, 01:04 AM   #5
g0lden
Drives: 2013 Scion FR-S Argento
Chevy's have door sagging/hinge issues LOL
Don't get a Chevy
g0lden is offline   Reply With Quote
Old 05-14-2013, 01:18 PM   #6
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
My Impreza wagon had 212k when I sold it... doors still aligned perfectly. I wouldn't worry about it.
SubieNate is offline   Reply With Quote
Old 05-14-2013, 08:30 PM   #7
Nezz
86DESU
Nezz's Avatar
Drives: 86 GTS, S13, CB9
The windowframe is a simple steel extension of the doorframe and has a rubber seal. So, yes, it does support the door-- vertically. It stops it moving upwards. By comparison, a plain window up against a rubber seal can move against whatever's controlling the regulator, and the rubber has to allow more pliance. Steel is more resistant to pressure than glass.
So basically what you're saying-- the car twisting against the doors (which is what happens) happens more with pillarless cars. Also, who told you 911s don't have issues with door sag? I know of about five that have had that corrected at a friend's workshop. Out of seven that've been in for bodywork that's a pretty big ratio.
EDIT; One thing, however, is that when you open and close BRZ/86 doors they reseat and unseat against the seal. That's nice, and should help. But, still. Point stands.
Careful. It's contagious!
Nezz is offline   Reply With Quote
Old 05-14-2013, 08:32 PM   #8
Nezz
86DESU
Nezz's Avatar
Don't think so off the top of my head. The stabilisers are a friction pad that holds the clip/latch base and tighter fitting clip/latch. A sliding plate enables the pressure without forcing the issue.
Old 05-14-2013, 08:40 PM   #9
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
Just get a few pieces of cardboard and glue it on the door jam. It does the same thing.
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 05-14-2013, 09:42 PM   #10
emutcfut
Drives: 2013 Argento
Got a DIY write-up for that?!?
emutcfut is offline   Reply With Quote
Old 05-14-2013, 09:49 PM   #11
wparsons
wparsons's Avatar
Hold up a second... are you suggesting that a window frame on the door that simply rests against a rubber seal on the body will stop a door from moving vertically???
Go have a close look at exactly just how a framed window door interfaces with the body of a car, there is literally no support added vertically. The only thing supported by a frame is the window.
A door is supported vertically by the hinges at the front and the pin at the rear, the body of the car doesn't hold up the door by the frame.
flickr
Old 05-14-2013, 10:02 PM   #12
Tromatic
So "door sag" in a frameless door is BS or not?
Old 05-14-2013, 10:13 PM   #13
wparsons
wparsons's Avatar
Door sag has nothing to do with the door having a window frame or not.
flickr
Old 05-22-2013, 01:18 AM   #14
Turdinator
Señor Member
Turdinator's Avatar
Thread from the dead i know, can you provive evidence of this?
1974 TA22 Celica
2013 86 GT
TRD Door Stabilizer Kit AL008 Australia Classifieds 3 03-17-2013 08:53 PM
FS; TRD DOOR STABILIZER photomike Brakes, Suspension, Chassis 1 03-07-2013 04:05 AM
EOI - TRD Door Stabilizer kit AL008 AUSTRALIA 2 02-28-2013 02:21 AM
TRD Door Stabilizer scioneric Canada Classifieds 15 01-22-2013 08:49 PM
TRD Door Stabilizer Set Psoo2010 AUSTRALIA 63 12-17-2012 06:35 PM
