Drives: 2013 Asphalt FRS
DRL problem
I just found out that my DRL is not working after i let go off my ebrake. I also checked the DRL fuse that was label in the fuse box, and the fuse look fine. I alsos checked to see if the high beam work and it does so it can't not be the bulb problem. Anyone has this problem before?
Drives: 2013 GBS BRZ Limited
They can be disabled in the ECU.
Are you the original owner? Unlikely to be disabled by the dealer. |
The DRL was working fine before. I just found yesterday that is not working for some reason. I guess i will wait until my next service and tell them that as well.
I haven't experienced that ..... but, I would suspect that the little "switch thing" in, or connected to, the e-brake is acting up.
I'd make sure your e-brake handle is going all the way down ... maybe even push it down a bit. humfrz |
#5 | |
ok, i will give that a try and let you know. Thanks! |
I try and push it down, still no luck
| The Following User Says Thank You to benlaz88 For This Useful Post: | Frstorm (09-17-2013) |
Drives: 2013 FR-S, Asphalt
I want this problem to happen to my car...
Turning is for Nerds
Drives: 35 characters is not enough
#10 |
Drives: Whiteout
Or just disconnect the resistor under passenger head lamp there is a DIY on here that I followed
#11 |
I was under the impression that some people had issues with removing the resistor? Something about the side mirror adjustment motors no longer working?
#12 |
Drives: 2013 Scion FRS
Please let ,e know what u find out about this issue mine stopped working when I first got car and yes my power mirrors do not work I checked fuses relays and even replaced stupid resister still nothing I don't care about the drl jus would like power mirrors to work sometimes
#13 | |
#14 | |
| The Following User Says Thank You to Decay107 For This Useful Post: | Hardrock4445 (09-19-2013) |
| First problem with the STX Brz | Simmons | Tracking / Autocross / HPDE / Drifting | 94 | 06-23-2014 12:05 AM |
| Has anyone have this problem....... | CSI:86 | Issues | Warranty | Recalls / TSB | 29 | 06-17-2013 09:29 AM |
| DDM HID Problem | LinknLog | Cosmetic Modification (Interior/Exterior/Lighting) | 18 | 04-11-2013 12:43 PM |
| A bit of a problem | Gost | Other Vehicles & General Automotive Discussions | 13 | 02-12-2013 07:07 PM |
| Problem! | axss | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 11-24-2012 02:31 PM |
