Drives: 16' WRX
RPF1 most flush?
This might be a noob question and I looked at the sticky, but none of the threads gave me a definitive answer. Which size combo on a RPF1 works best with a stock ride height of a BRZ? I looked around and mostly I've seen people with 17X8 +45 and 17X8 +35. Which is the best setup if I'm planning on keeping stock coils/springs for a while? Oh, and I can get 50% off Continental tires so what size and type should I get on those? Thanks and hope you guys understand that this is my first time purchasing rims for a car
I'm running 17x8 +45 with 225/45/17 tires all around on stock suspension/alignment, front is almost totally flush, a 3-5mm spacer (for +42 or +40) would be dead on. 17x8 +35 will poke a bit, but if you add any camber it'll be more flush. Rears would be better with +35, mine are in at least 8mm from the fenders still.
With an 8" wheel you won't have rubbing issues, if you go with 17x9 +45 you'll most likely run the stock strut spring seat (coilovers or spacers are the only fix for this) and +35 will poke quite a bit without adding camber.
+35 is the choice to make!
Want to revive this discussion real quick - I've been thinking on getting 17x9 +35 all around with completely stock suspension - will I run into any issues? Will the poke on the front be completely undesirable?
If anyone has pictures, would be greatly appreciated!
| Brake flush question... | N_I_N | Tracking / Autocross / HPDE / Drifting | 18 | 06-09-2013 07:13 PM |
| Flush mount tails? | Hardrock4445 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 03-25-2013 09:23 PM |
| Gas cap cover not flush with body? | CrazyWookiee | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 08-19-2012 10:32 PM |
| Flush +/- | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 08-13-2012 11:37 AM |
| Help with DIY transmission flush. | ahausheer | Other Vehicles & General Automotive Discussions | 0 | 06-26-2012 03:51 PM |
