Old 06-04-2013, 07:36 PM   #1
N_I_N
N_I_N's Avatar
Drives: FR-S [Hot Lava]
Brake flush question...
I have a Motive Power Bleeder (or I should say I borrowed one). Everything I have seen online says to leave the existing fluid in and pump it out as you are putting new fluid in.
...but in talking with another friend who does track days - he says he pumps all the OLD fluid OUT FIRST. Then pumps in the new fluid.
Which is correct? Or is either OK? This is my first go at this so the easier the better so long as I don't screw up my brakes.
N_I_N is offline   Reply With Quote
Old 06-04-2013, 07:50 PM   #2
oofie
The downside with flushing out the old fluid and not putting in new fluid is you have to do double the work. With this method, you will just fill all the lines with air, and do another "flush" to replace the air with the new fluid. The upside is that you can be assured that you have brand new fluid in all your lines.
If you do what most people do, which is just empty the reservoir and put in new fluid, you just wait until you see clean fluid coming out of the valves. I guess the downside here is that there is a chance you can have the old and new fluid mix, unless you flush out a whole lot of fluid.
oofie is offline   Reply With Quote
Old 06-04-2013, 11:44 PM   #3
Doborder
Godzilla Konvert
Doborder's Avatar
Drives: DMG BRZ Limited 6MT 2013
I would just put two new bottles of fluid in the motiv and just bleed until new fluid comes out. I will say that if you do take out all the old fluid from the reservior, make sure you do not introduce air into the system... It will be a bi#$h to get all the air out of the lines. Ask me how I know...
2013 Subaru BRZ Limited MT (DMG)
CO>CA Cartel
Doborder is offline   Reply With Quote
Old 06-05-2013, 10:03 AM   #4
N_I_N
N_I_N's Avatar
That's exactly what I'm afraid of... I'm using the Motul RBF600 and I guess it's the same color as the stock fluid so seeing when the new fluid starts might be a little challenging. But I only have 3 bottles of fluid and I would hate to drain everything and run out trying to get all the bubbles out if I drained it first...
I'm just going to stick with leaving the old in this time.
Old 06-05-2013, 12:04 PM   #5
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I ended up using superblue so I could tell when the old fluid was out and the new fluid was in. I drained half of the old fluid out of the reservoir and put the new fluid in the power bleeder. Next flush I'll switch to a different color so I can tell when the new fluid is in.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 06-05-2013, 12:21 PM   #6
Generally, we use the "two person" method, and will bleed one corner till clean fluid is coming out. Then we'll do the other three. Then, we'll do one more round, to make sure there's no contaminated fluid left.
Cheap and effective; you can bleed with 500ML if you're careful.
Old 06-06-2013, 01:11 AM   #7
Doborder
Godzilla Konvert
Doborder's Avatar
I don't like superblue because it is hard to flush it out later. May stain reservoir
CO>CA Cartel
Old 06-06-2013, 05:58 AM   #8
NZ86
Drives: GT86, 83 RX7
How do you know? I take it you have been through this experience, what did you have to do to get the air out?
I changed the fluid by removing the old fluid from the reservoir first and I think I have introduced air into the cylinder.
In the manual it says you have to remove the two brake lines from the cylinder, press and hold the pedal, block the two holes with your fingers, then release the pedal. Repeat 3 to 4 times.
Any help would be most appreciated.
NZ86 is offline   Reply With Quote
Old 06-06-2013, 07:36 AM   #9
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
I just had my dealer do it; cost me around $115 including Motul RBF600 fluid (yes, my dealer stocks it!) for a full flush PLUS cycling the ABS system to get the old fluid out of that as well.
The last time I did a full flush on my CTS-V, I could not get the air out of the ABS system for the life of me because I didnt keep the reservoir completely filled during the flush, causing air to get into the system, and it was a pain in the ass to get it out.
smbstyle is offline   Reply With Quote
Old 06-06-2013, 10:42 AM   #10
Doborder
Godzilla Konvert
Doborder's Avatar
I flushed two more times and gave up
Took it to my mechanic who hooked it up
To a machine which bled the ABS as well
Took them another 3 hrs to get air out
CO>CA Cartel
Old 06-06-2013, 10:50 AM   #11
oofie
How do you know if there's air in the ABS?
The Following User Says Thank You to oofie For This Useful Post:
kvnchu (06-06-2013)
Old 06-06-2013, 03:11 PM   #12
Doborder
Godzilla Konvert
Doborder's Avatar
don't know... That is what my mechanic told me!
CO>CA Cartel
Old 06-06-2013, 05:01 PM   #13
smbstyle
smbstyle's Avatar
No matter how much flushing you do, theres no air bubbles coming out, but the pedal still feels spongy. That's how I knew on my old car. I took it to the GM dealer who hooked it up to the computer, cycled the ABS system, and voila.
The Following 2 Users Say Thank You to smbstyle For This Useful Post:
Doborder (06-07-2013), oofie (06-06-2013)
Old 06-08-2013, 10:34 AM   #14
rx3
I used to drain the reservoir by simply sucking out braking fluid out of the top (with a manual piston pump) and then flush the entire system with new fluid. (Such that not the entire old brake fluid in the reservoir would be flushed through the system.)
I've never heard or seen anybody who purposely would get air into the braking system (this is something you would always try to avoid).
rx3 is offline   Reply With Quote
Question, would 19'' wheels cause my car to brake differently? Mr.Zoolittle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 06-29-2013 04:26 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
Gas cap cover not flush with body? CrazyWookiee Scion FR-S / Toyota 86 GT86 General Forum 3 08-19-2012 10:32 PM
Flush +/- DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 08-13-2012 11:37 AM
Help with DIY transmission flush. ahausheer Other Vehicles & General Automotive Discussions 0 06-26-2012 03:51 PM
