Old 07-13-2013, 11:28 PM   #1
brillo
Drives: 2013 Firestorm FR-S
Aeroquip socketless AN fittings / hose question
Wanted to post this more generally as the homebrew oil thread might not get enough traffic.
I installed a oil cooler this weekend using the mocal sandwich and aeroquip AN 10' hose and aeroquip sock less fittings.
I appeared to have a slight oil leak/drip with one of the aeroquip fittings near the sandwich plate. I tightened them both down further and it appears to have largely gone away but I still detect a hint of oil on the bottom of one of the fittings after driving (the potential area is where the fitting screw and housing meet, not the hose).
We used locktight on the threads so I'm pretty confident that if there is a issue its the fitting not where the fitting meets the sandwhich or the hose.
Car drives fine, warms up fine, oil level is stable. initial drip was tiny and not detected when we tested the car prior to driving.
1. Do the aeroquip fittings take time to seal?
2. If I have a bad fitting, can I replace without damaging the sandwhich or hose?
3. Do I need to replace the hose if I replace the fitting? I'm not sure what happens when you try to remove a socketless fitting from the hose.
I intend to inspect further tomorrow and continue testing, but I'm not sure what to expect with the aeroquip products having never used them.
Thoughts on other solutions? tighten more?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 07-14-2013, 07:31 AM   #2
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
if it's leaking from the cone seat of the fitting, remove and inspect the seat faces on both sides, if they're free of scratches/dents then they should seal just fine.
If you have AN to NPT fittings in the sandwich plate, I use a Loctite liquid thread sealer when installing those fittings.
If you have a damaged aeroquip fitting, you basically have to cut the hose off just after the fitting and press in a new one.
JP is offline   Reply With Quote
REV Motoring intake hose? zooki Engine, Exhaust, Transmission 15 07-20-2014 10:51 AM
Perrin Radiator Hose Oburn Engine, Exhaust, Transmission 8 06-19-2014 05:13 PM
Dual Catch Can, hoses and fittings Sportsguy83 Engine, Exhaust, Transmission 9 02-21-2013 01:13 AM
where to plug the oil catch can hose... :S dompower Engine, Exhaust, Transmission 29 11-14-2012 12:30 PM
Fuku Works Radiator Hose Kit Mach V Dan Engine, Exhaust, Bolt-Ons 4 09-12-2012 11:22 AM
