Old 06-17-2013, 07:59 AM   #1
Oburn
Drives: 2013 Subaru BRZ
Perrin Radiator Hose
Anyone install the Perrin radiator hose and if so how difficult isnit and how much time generally would it take?
Oburn is offline   Reply With Quote
Old 06-17-2013, 03:47 PM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I installed them, but I was also changing my radiator at the time. I would say it can be done in under an hour. You will want to jack the car up and remove both of the undertrays I believe and then drain the radiator and swap the hoses. I removed my top hoses by unbolting the radiator cap area and disconnecting the hoses from the motor and radiator. Then I swapped the hoses on the radiator cap area off the car.
The Following User Says Thank You to King Tut For This Useful Post:
Oburn (06-17-2013)
Old 06-17-2013, 04:47 PM   #3
PERRIN_Mladen
PERRIN_Mladen's Avatar
Drives: '11 535i
The install of the radiator hose is very simple and straight forward. I sent you an email containing the set of instructions as well!
For a time frame, I would say you can do it in 30 minutes to 2 hours MAX depending on how comfortable you are working on your car.
PERRIN_Mladen is offline   Reply With Quote
Old 06-17-2013, 05:31 PM   #4
Oburn
Yeah I wrote the post before you emailed me back haha, I got the email thanks. I won't be doing the instal, a shop will be I just wnted to know a general time frame because they will be putting my Perrin CAI and revworks header tomorrow so I don't want too much more time put on the car tomorrow
I'm in no rush to get the hoses put on ill prob wait until I get the pulley and inlet hose from you guys.
Old 06-17-2013, 05:45 PM   #5
Oburn
You swapped out the radiator for another or do you mean just changed the fluid?
Old 06-17-2013, 05:46 PM   #6
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I swapped to the Full Blown radiator.
Old 06-19-2014, 01:31 PM   #7
martinEZ
martinEZ's Avatar
Considering we're talking about a cosmetic upgrade...
martinEZ is offline   Reply With Quote
Old 06-19-2014, 01:49 PM   #8
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Took me about an hour. You don't need to remove anything except the existing hoses. To drain the radiator there is a small panel in the plastic under tray made specifically for draining the fluid. You'll just need a short hose of some sort. Just remove the panel, attach the hose (I used a piece cut from aquarium cleaning hose), place bucket under, and turn the knob on the drain valve. The hoses are a little tough to get on but they will go on eventually. I've done it on two cars and I think I'll just coach people and not do another one myself as it's not very fun as you'll be leaning over the car a lot straining back muscles.
stockysnail is offline   Reply With Quote
Old 06-19-2014, 05:13 PM   #9
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
the king of radiator hose installer.
The Following User Says Thank You to Lverasky For This Useful Post:
stockysnail (06-19-2014)
ZetaPerformance 6PC Radiator Hose Kit Installed Lverasky Engine, Exhaust, Transmission 9 04-19-2013 12:04 PM
Zeta Performance - 6 Pcs Silicone Radiator Hose Kit (Pre-order) ZetaPerformance Engine, Exhaust, Bolt-Ons 20 04-18-2013 12:26 AM
Enjuku Racing - ISIS Silicone Radiator Hose Kit - ** NOW AVAILABLE ** Enjuku Racing Engine, Exhaust, Bolt-Ons 0 01-08-2013 04:37 PM
Zeta Performance - 6 Pcs Silicone Radiator Hose Kit ZetaPerformance Engine, Exhaust, Transmission 1 09-18-2012 10:17 PM
Fuku Works Radiator Hose Kit Mach V Dan Engine, Exhaust, Bolt-Ons 4 09-12-2012 11:22 AM
