Old 07-10-2012, 03:20 PM   #1
dompower
dompower's Avatar
Drives: BRZ sportech
Question where to plug the oil catch can hose... :S
Hi!
I bought a cusco oil catch tank and in the instruction, i can figure where to connect the second hose, the one on the passenger side..
can someone help me?
dompower is offline   Reply With Quote
Old 07-10-2012, 03:33 PM   #2
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
probably the PCV valve, but don't hold me to that..
Old 07-10-2012, 03:44 PM   #3
dompower
dompower's Avatar
I think I'll need a picture... :S
Old 07-10-2012, 04:08 PM   #4
PekoPeko
If you want to recirculate the exhaust gas, then that hose would attach to the intake where the plug piece that was included in the kit goes. However, since the tubing doesn't match with the stock pieces and isn't very long, you'll have to get creative to make it look good while still connecting securely.
This isn't really necessary to run the car, though, as you can simply have the tube dump down. As long as you check the tank so that oil doesn't overflow into the tube, you'll be fine. It's an emissions thing, though, so if your area checks for the EGR system to be intact, then you will fail upon inspection. But since the MAF sensor is before the EGR connection iirc, it won't flag the ECU and you may pass if the inspection is a simple plug and go test.
Also note that some racing tracks and organizations require emission equipment to remain in working condition. I know that for autox, SCCA requires it to remain recirculating for stock and st classes (not sure about the other classes). If I wasn't doing autox, I would simply have it dump down as it looks much cleaner imo without the tubing snaking over the engine.
I'll try to snap a picture of mine after work, if I remember :P
PekoPeko is offline   Reply With Quote
Old 07-10-2012, 07:28 PM   #5
dompower
dompower's Avatar
thanks a lot!
Old 07-10-2012, 10:56 PM   #6
PekoPeko
Initially, the tube from the catch can was zip-tied to the tube circled in red, only further down and out of sight, and dumping the fumes straight down. This was a very clean look, but I had to recirculate to stay legal in stock class for autox.
As I didn't have time to meander around home depot to figure out how to recirculate and make it look nice, I took it to a local shop and their quick jerry-rigging work is highlighted in yellow. I plan on redoing it, but it works for now.
Hope this helps!
Old 07-10-2012, 11:00 PM   #7
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
i have nothing agaisnt cusco but there catch cans arent functional at all.. As there not even baffled..
imravenit is offline   Reply With Quote
Old 07-10-2012, 11:01 PM   #8
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Originally Posted by PekoPeko View Post
Attachment 10139
Initially, the tube from the catch can was attached to the tube circled in red, only further down and out of sight.
Doesn't that tube feed into the passenger footwell?
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 07-11-2012, 12:00 AM   #9
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Yessir, that's the back end of the sound box.
Old 07-11-2012, 02:07 AM   #10
PekoPeko
ya, sorry... lack of sleep, not good thinking...
I meant that I had it tied to that tube going down so that it didn't flail about. The tube itself (the one from the catch can) was just dumping downward. Looked a lot better than how it looks now, but not exactly the most environmentally (or track) friendly way to do it though. Same as how it looks on Moto's car.
http://www.ft86club.com/forums/showt...ighlight=cusco
6th picture in first post.
Old 07-11-2012, 09:10 AM   #11
dompower
dompower's Avatar
ok it only deviate the system on the intake tube...
if you plug it into the sound generator your car will be very quiet... even boring... -_-
I've initially plug it on the noise generator, but I feel like something wrong...
thanks for the tips guys!
Old 07-11-2012, 09:27 AM   #12
d1ck
Drives: Black 2013 FRS
I'd like to add that it is important to retain the PCV system functionality as it is an important system. It provides airflow through the crankcase to keep your oil from turning acidic, and also helps preserve your piston rings by creating a vacuum in the crankcase under normal driving.
d1ck is offline   Reply With Quote
Old 07-11-2012, 09:59 AM   #13
onedollarodent
Drives: None
This is my understanding as well.
onedollarodent is offline   Reply With Quote
Old 08-04-2012, 09:50 PM   #14
CB762
CB762's Avatar
Drives: Scion FR-S
I wonder if you have found a way for cleaner install?
TIA!
CB762 is offline   Reply With Quote
Oil Catch Can? eblamble3 Engine, Exhaust, Transmission 4 03-15-2013 10:58 AM
Cusco Oil Catch Can for BRZ/FR-S at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 0 07-01-2012 03:16 AM
Purpose of oil catch can? denverizzles Engine, Exhaust, Transmission 1 06-28-2012 03:55 PM
Engine oil drain plug washer BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-28-2012 11:28 AM
Cusco Street Oil Catch Tank 0.6L in stock!!! IslandImportPerformance Engine, Exhaust, Bolt-Ons 0 06-05-2012 12:56 AM
