Old 07-07-2013, 11:24 PM   #1
philstar
philstar's Avatar
Drives: Argento FR-S
Question for those who installed aftermarket LSD
Just picked up a Tomei 2-way LSD for my FR-S and I had several questions.
Did you guys reuse the side bearings? It's my understanding that if i reuse the side bearings, I can use the original thickness washers on each side but if I install new side bearings, I may need to select different sized washers.
Did you guys get new set bolt locks for the ring gear bolts? I figure its just extra assurance that the ring gear bolts will not loosen.
Regardless I'll still be checking runout, backlash, tooth pattern, etc. but just trying to minimize downtime.
philstar is offline   Reply With Quote
Question to whomever has installed the DW 65 fuel pump... Sportsguy83 Engine, Exhaust, Transmission 24 01-18-2015 10:08 PM
BRZ Stock Head Unit + Aftermarket Amp + 3-way Components question daforce007 Electronics | Audio | NAV | Infotainment 13 04-14-2013 04:42 PM
Eibach Sportlines Aftermarket rims Question. HATED1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-22-2013 07:08 PM
Smoked aftermarket taillights installed omgwtfbbqsauce AUSTRALIA 36 01-09-2013 07:42 AM
Help:new aftermarket radio and question regarding speakers FR-Shadow Electronics | Audio | NAV | Infotainment 2 11-04-2012 07:58 PM
