Old 11-04-2012, 06:43 PM   #1
FR-Shadow
FR-Shadow's Avatar
Drives: 2013 Scion FRS
Help:new aftermarket radio and question regarding speakers
Ok so I recently installed the X940BT with the BeatSonic harness. Everything went smoothly and The Beat Sonic even has spare wires comming off of their harness. When I say spare I mean they already made it a 1 into 2 connections for easy wiring. So with that said the three that are spares are:
BLUE--I used the blue for the antenna remote and the spare came in handy when I had to connect the blue wire from the antenna harness.
YELLOW--the spare is unused as of right now (battery power)
RED--the spare is unused as of right now (accessory power)
Here is a picture of the wiring diagram sent with the beat sonic harness.
Now as everyone who has installed an aftermarket head unit knows you dont use a third harness that would normally be used on the OEM headunit.
My question is that I noticed my door speakers do not work like they did when I had the OEM headunit. I used to feel the bass in the doors and now there is nothing. Making me think they are not producing sound. When i go to the fading the speakers I hear are the ones in the dash up front and the two in the back. So diging back into the wiring i noticed there was a red and yellow wire on that third unused harness. Are those wires the door speakers? If not does anyone know what I am missing that those door speakers are not working. When replacing with an aftermarket headunit do those become inoperable?
Thanks for the help guys.
FR-Shadow is offline   Reply With Quote
Old 11-04-2012, 07:22 PM   #2
FR-Shadow
FR-Shadow's Avatar
Ok so i was searching and reading and i guess there is a blue wire remote that controls the amp in the trunk which controls the door speakers, i thought i installed everything right but Ill have to take a second look at that blue wire.
Old 11-04-2012, 07:58 PM   #3
FR-Shadow
FR-Shadow's Avatar
Wow so do I feel stupid. I thought I had the blue wire hooked up but then when I checked my T tap it wasnt taped into the wire. A little splice and replace the T tap and bam door speakers work. hahaha
BRZ Radio question Simmons Electronics | Audio | NAV | Infotainment 10 06-16-2013 01:42 AM
Thoughts on the BRZ radio/gps/speakers - Should we upgrade? dorkymork Electronics | Audio | NAV | Infotainment 21 01-30-2013 11:04 AM
Do any aftermarket radio/nav systems offer gauges ? brillo Electronics | Audio | NAV | Infotainment 9 12-22-2012 02:03 AM
Fitting the radio plug into aftermarket head unit GC GTS Aero Kit Electronics | Audio | NAV | Infotainment 1 10-29-2012 05:41 AM
Aftermarket 2DIN Radio Install DetroitJake Electronics | Audio | NAV | Infotainment 4 07-08-2012 11:17 AM
