Old 03-22-2013, 06:50 PM   #1
HATED1
HATED1's Avatar
Drives: 86
Eibach Sportlines Aftermarket rims Question.
Hey Guys, I was wondering if a 17 x 9 +35 rim will fit on an FRS lowered on Eibach Sportlines?
Also, would a 17 x 9 +30 rim work dropped on Eibach Sportlines?
Anyone know how bad the rear camber will be, im fine with -2 or -2.5.
As far as rear camber adjustability, i am aware that there is none, but will i have to worry about the 17x9's poking out of the wheel well? i prefer the negative camber over positive.
Thanks for your help, if anyone is running a similar set-up please post pics, as i am about to make a purchase.
Thanks again.
HATED1 is offline   Reply With Quote
Old 03-22-2013, 07:02 PM   #2
wparsons
wparsons's Avatar
+35 or +30 will definitely poke up front with a 9" wheel, check the fitment thread to find pictures of just how much.
9" +45 fits pretty flush up front, but will more than likely rub on the stock struts.
flickr
Old 03-22-2013, 07:08 PM   #3
HATED1
HATED1's Avatar
Drives: 86
Thanks, I don't mind a little poke, I will camber it up front at least 1 degree, I just want to know that if I drop it on springs I will be able to adjust the stock camber. Just want to know if I can get away with the sport lines rather than dropping money on coils.
◙◙◙ [NY Local] SPECIAL on Eibach Sportlines Installed | Real Auto Dynamics ◙◙◙ Kevin@RAD Announcements, Contests, Giveaways 48 06-07-2013 02:19 PM
SCION FRS/BRZ AFTERMARKET RIMS AND TIRES FOR LOCAL PICKUP $800 FRS-Jay Great Lakes 2 02-20-2013 07:06 PM
Eibach Sportlines on the BRZ - Blown Strut 01s0uljah Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 02-14-2013 02:09 PM
eibach sportlines clunking.. frsguy707 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 10-24-2012 11:42 AM
Eibach Sportlines Finally Available! PRO Import Tuners Brakes, Suspension, Chassis 1 08-22-2012 07:42 PM
