Old 09-24-2012, 07:50 PM   #1
daforce007
BRZ Stock Head Unit + Aftermarket Amp + 3-way Components question
Has anyone installed 3-way components (powered by an aftermarket amplifier); while retaining the original head unit? If so, I want to know how you installed everything! My understanding of the system is as follows:
  • The head unit lacks RCA outs.
  • The head unit powers the mids and tweeters.
  • The stock amp in the trunk powers the door speakers.
The plan is to:
  • Install the aftermarket amp in the trunk, opposite of the stock amp.
  • Replace the stock amp with a line output converter (bit-ten or lc7i)
How I *currently* plan to wire this up:
  • Splice the existing mid & tweeter's speaker wire, to run it to the line output converter (LOC) in the trunk.
    • This signal should be the full-range, correct? so I could just ignore the wiring from the stock amp?
  • Run RCAs from the LOC to the Amp, and run speaker wire back to the components up.
I was wondering:
  • If someone has devised a more efficient installation?
  • Where have folks installed passive crossovers?
    • Is there space around the dash?
    • Should I install them in the trunk and run all the wiring back to the front?
Any and all help would be appreciated!
daforce007 is offline   Reply With Quote
Old 09-24-2012, 08:44 PM   #2
illmatic
illmatic's Avatar
Drives: BRZ Limited 6MT, 02 AW, 03PSM WRX
Didn't really read the details of your post, but this build uses the OEM fujitsu ten head unit.
http://forums.nasioc.com/forums/show...php?p=36481713
illmatic is offline   Reply With Quote
Old 09-24-2012, 08:45 PM   #3
2forme
It's really difficult. The factory head unit has the crossover built into it. It powers the dash speakers directly while offloading the door speakers to the amp in the trunk. You're better off just getting an aftermarket head unit if you're dead set on using an amp with a 3 way setup.
On my install, I removed the stock amp, and put the crossovers there while putting the 5 channel amp opposite of th(both under the trunk "floor").
Old 09-24-2012, 11:01 PM   #4
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
You want to add something like JL Cleansweep into the setup.
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 09-24-2012, 11:43 PM   #5
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Actually it's very easy. This car is a piece of cake and the Nav unit works fine as there are NO crossovers built into it. See my link below for a partial build thread. Also got one on diymobileaudio.com
michaelahess is offline   Reply With Quote
Old 09-24-2012, 11:44 PM   #6
daforce007
Thanks for the input y'all. The spec sheet of the Audison Bit Ten states:
"Automatic de-equalization of signal fed into the high-level inputs (with supplied Test CD) if necessary. It can also be performed without the PC."
Knowing this, one could feed the door speaker's source (that is already being run to the stock amp) to the Bit Ten, and have it de-equalized to a full-range signal, correct? Or would I need to use the amplified signal from the stock amp?
Old 09-25-2012, 07:10 AM   #7
2forme
My experience was completely different. Are you sure you're talking about a BRZ? What is the model of your stock head unit?
Old 09-25-2012, 10:07 AM   #8
sure74
sure74's Avatar
Drives: 2016 Toyota 4Runner Trail Premium
Has anyone tested the stock amp inputs to see if they are full range? The head unit output only
has provisions for LF, RF, LR, RR. That leads me to believe that the inputs for the stock amp
are just split from the LF and RF with no processing (full range).
sure74 is offline   Reply With Quote
Old 09-25-2012, 11:22 AM   #9
michaelahess
Yup, limited. It's the Fuji 10 thing. Full range outputs out of the HU back at the amp for front channels. The rear speakers run off the HU and I don't use those, or the rear speakers.
Running a test tone through my amp directly and looking at my RTA then running through the HU, almost identical, for all intents and purposes.
I keep volume between 30-45, set gains so it covers the volumes I want. The unit may modify the curve at lower volumes, but I didn't check that.
Make sure your EQ is flat...
Old 09-25-2012, 11:22 AM   #10
michaelahess
Input to the amps is full range. Rear is run of the HU.
Old 09-25-2012, 11:57 AM   #11
sure74
sure74's Avatar
So you can place the LOC where the stock amp is. Grab the front channel inputs from the stock
amp inputs and grab the rear channel inputs from the rear speaker locations. This will minimize
the wire needed to light up the LOC.
Old 09-25-2012, 02:24 PM   #12
michaelahess
That's where I put my LOC, then I got a DSP, but it's still pulling from there.
My build thread links off the link below has some pics of it.
Old 09-26-2012, 03:34 AM   #13
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Can you tell what frequency response the stock speakers are seeing from the amp?
JoeBoxer is offline   Reply With Quote
Old 04-14-2013, 04:42 PM   #14
vignesh
Engineer
vignesh's Avatar
Drives: WRB 2022 Subaru Brz
Just to be clear, The front door speakers are powered by the stock amplifier right. The rest of the speakers in the car, the two speakers and tweeters on the dash and the rear speakers are all being powered by the head unit?. Right now i am running jbl p66s speakers in the doors and infinity reference speakers on the dash. The jbl's are 2ohms and have 55 watt rms. Does the stock amplifier have enough juice to power the jbl speakers?
I am thinking of getting the alpine power pack to boost the head unit's power output. the alpine power pack is good in that it can be tucked away behind the head unit, a much cleaner install.
vignesh is offline   Reply With Quote
OEM mic with aftermarket head unit phenom86 Electronics | Audio | NAV | Infotainment 13 05-09-2013 11:20 PM
FRS aftermarket head unit installation - wiring MindtheGap Electronics | Audio | NAV | Infotainment 35 01-14-2013 09:00 PM
Stock Stereo Head Unit Languages Bonburner Electronics | Audio | NAV | Infotainment 12 08-18-2012 08:41 PM
stock nav head unit outputs brzzz Electronics | Audio | NAV | Infotainment 2 07-13-2012 03:37 PM
Is the standard stock FRS head unit good to go if I.... Liquidsnake Electronics | Audio | NAV | Infotainment 2 06-17-2012 03:16 AM
