Old 06-28-2013, 10:58 PM   #1
256brz2013
Drives: 2013 white brz
fortune 500 didnt go low enough? what now?
Pardon my newb questions. I put my fortune 500 coilovers on and it lowered my front plenty. But i wanna get another .5 of an inch out of the rear. Someone mentioned getting new lower control arms? Or do i need to get a softer spring? Thanks for the help.
256brz2013 is offline   Reply With Quote
Old 06-28-2013, 11:02 PM   #2
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
PBM is in the works of some LCAs with two different mounting locations for the shock. One is lower than the higher, thus it will drop the height of your car about an inch or so by mounting it in that slot.
Idk if they're for sale yet or if any other LCAs offer something similar.
I doubt a change a spring rates will make any difference at all
TylerLieberman is offline   Reply With Quote
Old 06-28-2013, 11:08 PM   #3
256brz2013
yea.. i emailed fortune 500. Waiting to see what they recommend. But i'll see what all i can find control arm wise
Old 06-28-2013, 11:16 PM   #4
TylerLieberman
Drives: '24 GR86
What size wheels/tires are you running?
Old 06-28-2013, 11:19 PM   #5
256brz2013
17x9 rota grids +30 offset
Old 06-28-2013, 11:49 PM   #6
256brz2013
tires are 225/45 i believe
Old 06-29-2013, 12:08 AM   #7
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
Stance LCA's
CircuitJerk is offline   Reply With Quote
Old 06-29-2013, 12:09 AM   #8
256brz2013
thats what i was looking at
Old 06-29-2013, 02:12 AM   #9
EvoJoe
EvoJoe's Avatar
Drives: car
a 225/45 is kinda a tall tire, idk if you want to spend the money but if you put a 225/40,35 or 30 on it, it should bring it down a little bit i suppose...Besides stance, Agency power, Cusco, gt works, Megan all make LCA's but idk if they all add more low.
EvoJoe is offline   Reply With Quote
Old 06-29-2013, 06:17 AM   #10
CircuitJerk
Pull my finger...
Stance will but I don't remember the number.
Ninja Edit: almost an inch
Old 06-29-2013, 09:33 AM   #11
loogs
Drives: on cruise control
im about to do fortunes too. i was told you get a 3" drop all around if wanted which sounded to me like more than enough. how low are you and how low are you looking to go? can you post a picture so i can see? id really appreciate it
loogs is offline   Reply With Quote
Old 06-29-2013, 10:29 AM   #12
TylerLieberman
Drives: '24 GR86
There's only like 2 companies that I know of that make a 225/40 in a 17". 35 and 30 sidewalls are just nasty looking on 17s. Way too small.
I would say a 215/45 or a 235/40. 45 sidewall is tall with a 225 width but still not taller than people running 18s with 225/40s and are slammed on the ground.
If he wants to go lower, sidewall isn't going to change it that much. He needs different LCAs to move the mounting point lower. Though I don't know what he'll do about the front because if the rear gets lowered another inch from LCAs, the front won't get lowered the same and he car will have reverse rake.
Old 06-29-2013, 11:12 AM   #13
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Since the front is already as low as you would like it to go, adding the Stance LCA's will give you the rest of the drop you want. They lower the hub mounting point 25mm(an inch).
Since you only want the rear to go about a half inch lower, simply install the Stance arms and raise your rear coilover ride height until you reach your desired height.
Stance LCA's are in stock, as well.
FT-86 SpeedFactory is offline   Reply With Quote
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
charged86 (06-29-2013)
Old 06-29-2013, 11:14 AM   #14
charged86
charged86's Avatar
Or sell them to me
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Fr-s on Fortune Auto 500s Propaganda Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 02-10-2014 07:33 PM
Those with fortune 500 coilovers normanb21 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 05-06-2013 09:51 AM
Stance Vs Kw3 vs Fortune Autos? koyv90 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 57 12-29-2012 06:58 AM
Fortune Auto Coilovers doriNIGHTS Brakes, Suspension, Chassis 17 12-24-2012 04:05 AM
Fortune Auto vs BC Racing D1cker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 09-11-2012 10:18 AM
