Old 06-17-2013, 10:17 PM   #1
Ryeong86
Ryeong86's Avatar
Drives: 2015 Sti Launch Edition
HELP:Switchback led bulbs
I just installed my switch back led bulbs and hyper flash relay. The problem I'm running into is they don't light up when I turn on my head lights. They blink fine but stay off until I use my blinker. Aren't they supposed to light up with the head lights on?
\/Invidia N1 Titanium Tip Catback\/Rexspeed Carbon Fiber Front Lip\/Koni Sport Yellows\/Stivo Ducktail Lip Spoiler\/Porterfield Carbon Kevlar Front Pads\/TSW Nurburgrings 17x8 wrapped in 235/40/17 Nitto NT-05\/[/I]
Ryeong86 is offline   Reply With Quote
Old 06-18-2013, 09:09 AM   #2
tbwoodlee
I Void Warranties
tbwoodlee's Avatar
Drives: Asphalt 86
Hmmm... I dunno if this will solve it seeing as they light up as blinkers, but try taking the LED out and flipping it. Sometimes if the LED won't light up it is because the bulb is upside down.
tbwoodlee is offline   Reply With Quote
Old 06-18-2013, 10:12 AM   #3
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
Most likely this is your solution.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 06-18-2013, 11:56 AM   #4
Ryeong86
Ryeong86's Avatar
I did that this morning. When I switch the bulb around, it doesn't light up at all. When I put it back to the way I had it, it flashes when I use the blinkers, hazards or when I lock or unlock my car. They don't light up when I put on my headlamps, which I believe they should. I'm going to put everything back to stock and see if it's the bulb or something else. Also Pm'd HID Powerhouse to see if they have a solution.
Old 06-18-2013, 12:26 PM   #5
Tim_Asphalt_FRS
Is it fast? No.
Sounds like you have defective bulbs. Can you get a refund or replacement?
Old 06-18-2013, 12:37 PM   #6
Ryeong86
Ryeong86's Avatar
working with Hid Powerhouse right now to figure this out.
The Following User Says Thank You to Ryeong86 For This Useful Post:
Tye300 (06-18-2013)
Old 06-18-2013, 12:40 PM   #7
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Same thing happened to me. I'm thinking that the wiring might be different with the Philippine spec than the usdm spec cars. I ordered from HID powerhouse also and when I installed the bulb it just blinks but does not light up when I turn my headlamps on.
Tye300 is offline   Reply With Quote
Old 06-18-2013, 12:54 PM   #8
Ryeong86
Ryeong86's Avatar
Im trying to find the fuse for the turn signals but I don't think it's blown... if it was, the turn signals wouldn't work at all.
Old 06-18-2013, 09:27 PM   #9
KI_ZN6
KI_ZN6's Avatar
You have PM, it should be something minor =)
KI_ZN6 is offline   Reply With Quote
Old 06-18-2013, 09:28 PM   #10
wparsons
wparsons's Avatar
The easiest way to test the wiring/etc is to put the stock bulbs back in and make sure they light up with the parking or head lights on. If they do and the LED bulbs don't you know it's the LED bulbs. If they don't then it's the car.
flickr
Old 06-19-2013, 04:42 PM   #11
iJDMTOY
iJDMTOY's Avatar
Drives: 2008 Honda Civic Si
Are resistors installed with the lights? That MAY fix the issue, but I haven't seen a problem like that on a FR-S before. On a Kia Optima/Sonata, it's required to have load resistors or else switchbacks will not work correctly.
It just sounds like a defective bulb it seems if the white does not turn on, on the FR-S's we've tested on, it should work regardless, it'll just hyper-flash
iJDMTOY is offline   Reply With Quote
Old 06-20-2013, 12:09 AM   #12
914_WHITE_FRS
914_WHITE_FRS's Avatar
Drives: White 2013 Scion FR-S
I installed my switch backs all i had to do install my relay and bulb and it worked. Make sure when u plug the bulb in make sure before sealing everything back in go turn the switch on in ur car to see if turns on if not then adjust the bulb opposite way to find out which way turns on
914_WHITE_FRS is offline   Reply With Quote
Old 06-20-2013, 02:05 AM   #13
AintTrying2Race
AintTrying2Race's Avatar
Not to be rude to the op, But I was just wondering where I can get the best switchback led and relay for my FR-s. I've been looking around the forum and it seems most switchback bulbs and relay are the same except for how bright you want the bulb to be. What concerns me is the solution to fix the hypher blink using the relay, it has some sort of lag time when the light switches from white to amber or vice versa. I've seen videos on this forum and others where it shows this lag. Now, these videos were posted a couple months old even a year, Im not sure if most vendors have fixed this but is the lag due to the bulb or relay being used or both?
AintTrying2Race is offline   Reply With Quote
Old 06-20-2013, 11:37 AM   #14
Ryeong86
Ryeong86's Avatar
It was the bulbs after checking all fuses and reverting back to stock. Major props to HID powerhouse for replacing the bulbs and trying to help diagnose the problem.
FS: Concept3 switchback bulbs. wparsons Canada Classifieds 11 08-11-2013 07:58 AM
Switchback signals, which bulbs did I actually want? wparsons Cosmetic Modification (Interior/Exterior/Lighting) 13 05-24-2013 06:59 PM
Need Help w/ Switchback LED! bhbnuckle Cosmetic Modification (Interior/Exterior/Lighting) 1 04-30-2013 10:10 AM
switchback LED assistance Gen Cosmetic Modification (Interior/Exterior/Lighting) 2 10-09-2012 10:41 PM
Switchback LED's SocalBurt Cosmetic Modification (Interior/Exterior/Lighting) 7 09-03-2012 01:37 PM
