Drives: red frs
Audio genius needed...
Ok this is a bit of a stretch I am sure, but I am not an audio guy by any means.
I have a base head unit and I have no use for it basically. I was wondering if there was a way i could run an xm unit and only an xm unit. I would like to remove the big ass box in my dash and use just an xm controller. I dont need cd, am/fm. i would love to keep blue tooth if i could. My main goal is to remove the big oe unit out of the dash and replace it with the smaller xm controller leaving room for guages/performace electronics. i know they have hidden radio units for street rods but i didnt want eat up my whole glove box either. |
Drives: Argento 6spd FR-S
Sure, its gonna cost you quite a bit tho. In a nut shell you would need the following....
A motorcycle XM kit A car XM antenna with compatible plug for above kit. 3.5 to rca adapter Amp to power speakers either 2 or 4ch Amp kit The volume would be controlled through the xm unit. You would lose BT. In the end it would sound terrible and cost a lot. If you want XM and want to put some gauges there.... then get a single din. 3 gauges are more than enough for monitoring. Then you spend like 250 and get to keep a simple system that will sound decent as you can get from XM and have BT. |
Enthusiast
Drives: 2013 Scion FR-S (37J)
Just get a single din with BT and XM, then put gauges above/below it!
Drives: red frs
Drives: 2001 ZX2, WRBP BRZ (soon hopefully)
There's no way you are gonna get BT/xm without a head unit so suck it up and buy one or build it.
Sent from my SPH-L710 using Tapatalk 2 |
If you don't want CD you could always get a mechless unit from Sony or Alpine.
#8 | |
Drives: red frs
![]() i was asking if it was possible, i dont know if it is because i dont deal with audio stuff on a regular basis. i did find a unit but i think its an add on to an older style head unit. http://www.ebay.com/itm/XM-Sirus-Sat...5da394&vxp=mtr |
Drives: red frs
#10 | |
#11 |
these two components are your best bet
deck http://www.sonicelectronix.com/item_...X-S310BTX.html xm module http://www.sonicelectronix.com/item_...n-Package.html |
#12 |
Drives: red frs
#13 | |
Drives: red frs
#14 |
Its not just for apple products... USB sticks can be used with it too
| SoCal Audio Shop Needed | dlux | Southern California | 5 | 05-17-2013 05:24 PM |
| Some genius scratched my car | Wally Simmonds | AUSTRALIA | 17 | 04-25-2013 11:31 AM |
| FR-S Audio Build - SQ (Illusion Audio/Mosconi) | DekaMori | Electronics | Audio | NAV | Infotainment | 28 | 04-17-2013 04:34 AM |
| Lug Nut Help Needed | USMC -FRS | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 01-17-2013 10:06 PM |
| 'Noobish' questions as I look to upgrade my car audio audio. | DkY in Vcr | Electronics | Audio | NAV | Infotainment | 0 | 09-22-2012 09:45 PM |
