Old 05-31-2013, 04:19 PM   #1
Shit Luck
Drives: red frs
Audio genius needed...
Ok this is a bit of a stretch I am sure, but I am not an audio guy by any means.
I have a base head unit and I have no use for it basically. I was wondering if there was a way i could run an xm unit and only an xm unit.
I would like to remove the big ass box in my dash and use just an xm controller. I dont need cd, am/fm. i would love to keep blue tooth if i could. My main goal is to remove the big oe unit out of the dash and replace it with the smaller xm controller leaving room for guages/performace electronics.
i know they have hidden radio units for street rods but i didnt want eat up my whole glove box either.
Shit Luck is offline   Reply With Quote
Old 05-31-2013, 04:53 PM   #2
cruzinbill
Drives: Argento 6spd FR-S
Sure, its gonna cost you quite a bit tho. In a nut shell you would need the following....
A motorcycle XM kit
A car XM antenna with compatible plug for above kit.
3.5 to rca adapter
Amp to power speakers either 2 or 4ch
Amp kit
The volume would be controlled through the xm unit. You would lose BT. In the end it would sound terrible and cost a lot.
If you want XM and want to put some gauges there.... then get a single din. 3 gauges are more than enough for monitoring. Then you spend like 250 and get to keep a simple system that will sound decent as you can get from XM and have BT.
cruzinbill is offline   Reply With Quote
The Following User Says Thank You to cruzinbill For This Useful Post:
JoeBoxer (06-02-2013)
Old 05-31-2013, 06:07 PM   #3
BigJyoungblood
Enthusiast
BigJyoungblood's Avatar
Drives: 2013 Scion FR-S (37J)
Just get a single din with BT and XM, then put gauges above/below it!
BigJyoungblood is offline   Reply With Quote
Old 05-31-2013, 07:14 PM   #4
Shit Luck
Drives: red frs
if i wanted that i would have done it already...
Old 05-31-2013, 08:32 PM   #5
Sbeezy
Drives: 2001 ZX2, WRBP BRZ (soon hopefully)
There's no way you are gonna get BT/xm without a head unit so suck it up and buy one or build it.
Sent from my SPH-L710 using Tapatalk 2
Sbeezy is offline   Reply With Quote
Old 05-31-2013, 08:34 PM   #6
Sbeezy
If you don't want CD you could always get a mechless unit from Sony or Alpine.
Old 06-01-2013, 02:06 AM   #7
cruzinbill
He wants to be complicated tho.... I already gave him a way that would work even tho its not worth the time or money to have it.
Old 06-01-2013, 10:54 AM   #8
Shit Luck
Drives: red frs
your right the whole point of this thread was so I be complicated not because i have a specific goal in mind for my build up.
i was asking if it was possible, i dont know if it is because i dont deal with audio stuff on a regular basis.
i did find a unit but i think its an add on to an older style head unit.
http://www.ebay.com/itm/XM-Sirus-Sat...5da394&vxp=mtr
Old 06-01-2013, 11:00 AM   #9
Shit Luck
Drives: red frs
looks like they arent xm ready from what i can tell...
Old 06-01-2013, 01:27 PM   #10
Sbeezy
thats an amplifier not an xm module
Old 06-01-2013, 01:42 PM   #11
Sbeezy
these two components are your best bet
deck
http://www.sonicelectronix.com/item_...X-S310BTX.html
xm module
http://www.sonicelectronix.com/item_...n-Package.html
Old 06-01-2013, 01:43 PM   #12
Shit Luck
Drives: red frs
i understand that, however i can run xm through that with the fm adapter on a standalone xm unit.
i think... i see a bunch of motorcycle amps but they are 2 channel.
Old 06-01-2013, 01:46 PM   #13
Shit Luck
Drives: red frs
looks pretty cool. I dont own any apple products but that is a neat idea for people who do.
Old 06-01-2013, 01:55 PM   #14
Sbeezy
Its not just for apple products... USB sticks can be used with it too
SoCal Audio Shop Needed dlux Southern California 5 05-17-2013 05:24 PM
Some genius scratched my car Wally Simmonds AUSTRALIA 17 04-25-2013 11:31 AM
FR-S Audio Build - SQ (Illusion Audio/Mosconi) DekaMori Electronics | Audio | NAV | Infotainment 28 04-17-2013 04:34 AM
Lug Nut Help Needed USMC -FRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 01-17-2013 10:06 PM
'Noobish' questions as I look to upgrade my car audio audio. DkY in Vcr Electronics | Audio | NAV | Infotainment 0 09-22-2012 09:45 PM
