Old 01-17-2013, 07:12 PM   #1
USMC -FRS
USMC -FRS's Avatar
Drives: 2013 FR-S. Raven 6 AT
Lug Nut Help Needed
Guys, I really want to put red lug nuts on my Raven with stock wheels. But I read a lot of information that tells most aftermarket Lugs state they are not for stock rims. Can anyone provide some help on a brand that works.
USMC -FRS is offline   Reply With Quote
Old 01-17-2013, 07:23 PM   #2
OrbitalEllipses
Drives: Attitude
60 tapered aka tuner lugs will work with stock wheels because Subaru is weird like that. Stock wheels are tapered IIRC.
Old 01-17-2013, 07:33 PM   #3
ayau
Drives: Some rust bucket
It's going to look weird with aftermarket (tuner) lugs. The "lip" of the tuner lug is longer, which means it will stick out of the OEM lug nut holes. See picture below for a comparison. It's best to stick with OEM lugs if you're using OEM wheels IMO.
Left: aftermarket lug
Right: OEM lug
Old 01-17-2013, 09:02 PM   #4
OrbitalEllipses
Drives: Attitude
Right: OEM lug
The taper is what's important. Both have a 60 degree taper; thus they are entirely compatible. Though I agree that the exposed lug seat is a poor choice if not aesthetically then corrosion wise.
Old 01-17-2013, 10:06 PM   #5
kanundrum
Drives: 2013 Whiteout FR-S
Buy what ever lugs you want and some high temp enamel paint. Sand down the lugs follow instructions for high temp painting and your good to go, sure with wear and tear they may flake a little but not by much and you can get the color you want.
FR-S needed in Miami. greenguy101 Southeast 8 10-19-2012 01:08 PM
MOD's Needed. Help Please! GT-ROKIN Cosmetic Modification (Interior/Exterior/Lighting) 17 10-06-2012 01:18 AM
Exhaust help needed Jordan6908 Engine, Exhaust, Transmission 1 06-26-2012 11:41 AM
Service needed after the second day Carlsbad BRZ First-Gen (2012+) — General Topics 15 06-04-2012 03:34 AM
All it needed was some JB Weld... 82mm 4g63 Other Vehicles & General Automotive Discussions 2 09-15-2011 08:12 PM
