Old 05-01-2013, 10:05 PM   #1
kendalldwhite
kendalldwhite's Avatar
Drives: Mint-Tiffany blue FRS
steering grinding
I took my stock Scion FRS steering wheel off to put on a Sparco one. Everything was un hooked involving the ABS and VSC lights. I went out today to re hook everything back up so the lights would go off. As I take it for a test drive, when I pick up speed and turn a corner, it makes a harsh grinding noise throwing the VSC light, it not only comes on it flashes. Could this be Power Steering?? Wheel bearing?? ABS however isn't coming on.
kendalldwhite is offline   Reply With Quote
Old 05-01-2013, 11:25 PM   #2
LavosTRD
Toyota Master Tech
Drives: Whiteout MT
Either you left the steering angle sensor unplugged, or it needs to have a zero point calibration performed. The sounds is your traction control kicking on because its getting no/inaccurate steering angle values.
LavosTRD is offline   Reply With Quote
Old 05-02-2013, 08:38 AM   #3
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
x2
Chimpo is offline   Reply With Quote
6th gear grinding D-VO Issues | Warranty | Recalls / TSB 59 04-07-2015 01:26 PM
Awful grinding!!! DatGoodBRZ Issues | Warranty | Recalls / TSB 13 11-09-2012 04:13 PM
Grinding / Shaking under emergency braking Kurenai Issues | Warranty | Recalls / TSB 16 11-05-2012 09:52 PM
Slight grinding from the brakes... kndonlee Other Vehicles & General Automotive Discussions 7 09-15-2012 05:14 PM
Manual grinding sound deedz Engine, Exhaust, Transmission 22 07-20-2012 10:05 PM
