Old 11-25-2012, 10:46 PM   #1
D-VO
Drives: Whiteout FR-S, Evo 8 RS
6th gear grinding
Hey all
I normally skip gears as a drive and typically shift 1, 3, 6. A couple of days ago I revved 3rd gear out to about 5k rpm, shifted into 6th and had a really bad grind. Last night I decided to check any other combinations that would create a gear clash and found that generally any gear into 6th past 5000 rpm would grind. Is anyone else having this issue?
D-VO is offline   Reply With Quote
Old 11-25-2012, 10:51 PM   #2
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by D-VO View Post
Hey all
I normally skip gears as a drive and typically shift 1, 3, 6. A couple of days ago I revved 3rd gear out to about 5k rpm, shifted into 6th and had a really bad grind. Last night I decided to check any other combinations that would create a gear clash and generally any gear into 6th past 5000 rpm would grind. Is anyone else having this issue?
you're over working your syncros. try 1-2-3-4-5-6 or at least 1-2-3-4-6
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 11-25-2012, 11:18 PM   #3
JohnS_Rosamond
Drives: Mazda MX5
As I understand, 6th gear is less that 1:1, like an overdrive. Reving the car real high then is not what 6th gear would want in order to engage smoothly. I don't really see what advantage skipping two gears has, from 4th to 6th? If you don't want to shift, why not get the automatic? Anyway, I believe the main problem is that you are not matching the rev's correctly - that's why it's grinding.
JohnS_Rosamond is offline   Reply With Quote
Old 11-25-2012, 11:37 PM   #4
mashal
DADA
mashal's Avatar
Drives: 2013
Cars have gears because they need them , 1-2-3-4-5-6 Learn to shift in that pattern and your car is asking you wtf your doing "grinding noise"
I-Tapatalk
mashal is offline   Reply With Quote
Old 11-25-2012, 11:42 PM   #5
D-VO
I've always skipped gears in all my cars, so I figured it would be fine in this one. I skip gears because the engine has enough torque to accelerate well in the rpm range at which it falls when I skip gears.
I guess the problem now is since I'd like to race, the 6th gear grind will soon turn into a transmission rebuild. Thanks guys.
Old 11-26-2012, 12:18 AM   #6
Gen
Drives: Scion FR-S
4th grinds every single time over 5k RPM unless I take a good 2 seconds between clutch in and shift.
Gen is offline   Reply With Quote
Old 11-26-2012, 01:03 AM   #7
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Regardless of how you shift, you should not hear any grinding. Especially on a new transmission. Though shifting to top gear from a higher rpm will work the synchro harder, it should not create an issue with grinding.
I've had 3rd and 4th gear feel crunchy on shifts, but no grinding per se.
Coheed is offline   Reply With Quote
Old 11-26-2012, 01:32 AM   #8
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
hmm maybe you should change your shifting habits or transmission fluid
dori. is offline   Reply With Quote
Old 11-26-2012, 07:19 AM   #9
enigmaaron
enigmaaron's Avatar
Drives: '13 Firestorm FR-S MT, '04 Tacoma
Because when you've reached the proper speed for the road you are on in 3rd gear why should you have to go through 4 and 5 just to end up at 6 at the same exact speed.
OP - I've noticed the same issue. Even accelerating onto a highway up to speed in 5th and going to 6th quick once I reach cruising speed. I've learned to only go into six "casually". I.e. once I've reached speed in whatever gear cruise for a moment before shifting, and if I'm coming from really high RPMs I'll give the engine a couple seconds with the clutch in like someone else mentioned to come down before putting it into 6th.
enigmaaron is offline   Reply With Quote
Old 11-26-2012, 10:53 AM   #10
empower-auto
Kouki-Monster
empower-auto's Avatar
Change .. your .. shifting .. habits.
You're being lazy. Not clever. Don't take offense to this - because you're not driving it as you should be.
If it's not reasonable to do this .. I recommend purchasing an automatic.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 11-26-2012, 11:41 AM   #11
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Hey all
If you're skipping gears, you have to shift slower. Gotta wait until your revs drop some more or you'll grind.
raul is offline   Reply With Quote
Old 11-26-2012, 12:23 PM   #12
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I can shift into 6th well above 5000 RPM without any problems..but that is because I shifted from 5th...If I skip a gear (typically go from 4th to 6th) I let the engine wind down and I move it into 6th then when the engine speeds would match the gearing for going X km/h. You are just shifting bad.
Also, D-VO, "I skip gears because the engine has enough torque to accelerate well in the rpm range at which it falls when I skip gears." You do know this car has minimal torque right?
Old 11-26-2012, 02:34 PM   #13
ST185RC
Drives: White Out FR-S
It's a way your car is telling you that you are doing something wrong and your driving habits are hurting something. I'm perplexed on what advantage skipping gears is.
a) If you're just trying to get up to speed to cruise, skipping gears would put added wear on the higher gears to get you to the speed a lower gear could accomplish with significantly less wear. It's like you're getting a smaller guy who could lift 100 lbs to lift 150lbs instead where you could get a bigger guy who could lift the 150lbs easily and not break a sweat.
b) If you need to be in 6th gear to race, it wouldn't be territory where the 86 would feel most at home anyways on a high speed course.
I agree your driving habits gotta change to make the most of this car AND maintain the longevity.
ST185RC is offline   Reply With Quote
Old 11-26-2012, 02:50 PM   #14
enigmaaron
enigmaaron's Avatar
Why is this so hard for people to understand? If you go 1-2-3 and are at 50mph on a 50mph road why the hell would you go through 4-5 to get to 6 all while still at 50mph???
As mentioned many times now, just have to shift into 6 more casually. If you raced up to speed give the engine a moment with the clutch in to drop the RPMs before shifting into 6.
notchy/gritty transmission. every gear grinding prest1ge Engine, Exhaust, Transmission 41 12-09-2012 06:45 PM
Awful grinding!!! DatGoodBRZ Issues | Warranty | Recalls / TSB 13 11-09-2012 04:13 PM
Grinding / Shaking under emergency braking Kurenai Issues | Warranty | Recalls / TSB 16 11-05-2012 09:52 PM
Slight grinding from the brakes... kndonlee Other Vehicles & General Automotive Discussions 7 09-15-2012 05:14 PM
Manual grinding sound deedz Engine, Exhaust, Transmission 22 07-20-2012 10:05 PM
